Thread: my 83 200x kick start is not cranking
    Dec 2014
    alberta canada
    34
    when i kick start the my 200x it dosnt turn motor but then it will catch on one spot and crank the engine so i took apart couldnt find any stripped gears. Any idea s ??
    Attached Thumbnails Attached Thumbnails 100_5356.JPG   100_5358.JPG   100_5357.JPG
    Slidell, LA
    4,738
    Pic number 1. The ratchet on the shaft and the kickstarter gear to the left are stripping. They dont look like it, but they are. You need to search high and low for an NOS ratchet and gear. It would also be a good idea to replace both springs while you are in there.
    Dec 2014
    alberta canada
    34
    looking at the pic here is how they mesh looks like its okClick image for larger version.
    Slidell, LA
    4,738
    Again, they won't appear stripped, they are. Plus your ratchet spring isn't expanding like it use to when it rolled off the line in '83. Done 4 of these now. Reassemble it and roll the dice or find NOS springs and gears...up to you.
    6,801
    Very simple the spring doesn't keep enough pressure on the ratchet thus causing it to slip . Best to replace both ratchet gears and install a new HD spring .
    Dec 2014
    alberta canada
    34
    ok thanks for the help ill try different gears and shim the spring to make it tighter, its very hard to find parts with out buying a whole parts bike , right now i have 2 bikes trying to make one good one.
