Page 6 of 13 FirstFirst ... 4 5 6 7 8 ... LastLast
Results 76 to 90 of 195
Thread: 86 KXT Build
  1. #76
    phantomtracer's Avatar
    phantomtracer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    392
ID:	221551Click image for larger version.
ID:	221552Click image for larger version.
    Had trouble installing piston dust seal, found the best way is to first install the seal onto the bottom on the brake piston and then install the other side of the seal into the caliper body while holding the piston just outside the piston bore, a little persuasion with a plastic tool helped to get it seated. Then slide the piston into the caliper until it bottoms out and the dust seal will automatically be pushed into the piston groove on the top. It's hard to explain but if anyone has struggled with this they will know what I mean.
  2. #77
    Surprise, AZ
    2,428
    Did you grease the seals?
    SF-3 works great
    Sent from my SM-G386T1 using Tapatalk
  3. #78
    Pa
    392
    I used a silicone spray on the seals and synthetic grease for the slider pins.
    A
    Quote Originally Posted by onformula1 View Post
    SF-3 works great
  4. #79
    Pa
    392
    Finally found the correct rear piston seals for the master cylinder.
    Should be a big step forward next week when I drop a bunch of stuff off to be blasted the painting it asap.
  5. #80
    Jan 2013
    minnesota
    5,911
    Are you actually going to ever ride this beauty?
  6. #81
    Pa
    392
    Thanks for the kind words, I hope to ride at the imperial invasion if I can make it out there.
  7. #82
    Pa
    392
    Powder coated spring and fender support
    Media blasted parts, ready for paint!!!!
  8. #83
    Pa
    392
  9. #84
    Jan 2013
    minnesota
    5,911
    Hey phantomtracer, I just happened across these photos that were taken of a new Tecate in our design studio . . I posted the link so you can see the color of the plating on some of the parts in case you still need that info.
    http://www.atvrider.com/1986-kawasak...heeler?image=0
  10. #85
    Pa
    392
    Thanks, I have been referring to them often.
    Here is the finished shock with recently powder coated spring
    Here is the newly painted swing arm.
    I'm about to mount the engine into the frame. Can't wait.
  11. #86
    Pa
    392
    What am I missing? Are there spacers?
  12. #87
    Nov 2014
    Chico,CA
    473
    Looks like you are missing the "Ref.Frame Fitting" so yeah two metal plates are missing from this picture.
  13. #88
    Pa
    392
    LOL!!!!!!
    WOW!!!
    Its been a long day.
    Thanks for the help.
    I will not post anymore today to avoid embarrassing myself.
  14. #89
    tecaterob is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Miami Fl
    435
    And the buttom of those plates is what holds the shock.
    3 86 Tecate 3
    1 87 tecate 3 (with kx 540 motor)
    1 87 tecate 4 (with 330 motor, 250r geometry)
    1 83 atc 70
    1 Kfx 50
    1 kfx 400 ( with 470 parting out bike)
    1 78 KZ 1000 ( with 1340 turbo)
    1 Aprilia SXV 550 Supermoto
    1 01 ZRX 1200 prostreet (sold)
  15. #90
    Dimitris's Avatar
    Dimitris is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2009
    Greece
    167
    Nice work friend Philip. Amazing build
