Results 1 to 15 of 15
Thread: Luck was on my side this time
    O.C., Oregon
    921
ID:	211869Click image for larger version.
ID:	211868Click image for larger version.
    The pic tells all, it cracked all the way through to the wrist pin then started to burn a hole and pop. Could have been real bad but luckily she held together. Cylinder and head look perfect still! Whew! Last ride out at Florence my buddies bansheet took a crap about 2 miles away from camp and i had to get him back as 3 different people declined to help us... Towing with a 2 stroke is always kinda sketch but in the sand it's much harder on things and towing a fat quad didn't help either. This piston has only about 25 hours on it. It's a Pro-x which have a pretty good reputation but after this it's only forged for me. I run weisco pistons in my YZ250 and love them. My motor builder liked the pro-x and said he's never seen them fail really so against my better judgment i went with it. I'll put up some pics of the cylinder and a better shot of the piston later.
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    wales..uk
    1,318
    happened to me about 10 years ago ......the piston cracked completely in half...mine was a OEM piston on original bore....i put out down to washing the bike down before the engine was cool enough??? changed the piston never had a problem since....
    Need Honda ATC TRX NOS restoration parts??? or come check out our ATC brochure site
    www.offroadvintage.com
    O.C., Oregon
    921
    We had to go through a few water crossing which may have contributed to the cracking. Hard to say.
    2017 YZ 250x- Braap
    Slidell, LA
    4,738
    Quote Originally Posted by 250rRoostmaster View Post
    Woah, that sucks. God was on your side my friend. I don't know that I have seen a piston do that, but anything is possible. Are you going back with a wiseco? I hear the Wossner pistons are of high quality.
    Haven't seen your bike close up before...I like it and still jealous of your LED pipe
    O.C., Oregon
    921
    Haha thank you sir! It had a cast Pro-x piston, so i will be going with a weisco moving forward.
    2017 YZ 250x- Braap
    That is a beautiful trike!! So glad you didn't grenade the whole cylinder!!
    Def not detonation, I bet it was the water. And I'd use a forged piston as well
    O.C., Oregon
    921
    A few more pics to show how damn lucky I was... I put a lot of work into her so i appreciate the comments on my bike guys!
ID:	211925Click image for larger version.
ID:	211926Click image for larger version.
ID:	211927Click image for larger version.
ID:	211928Click image for larger version.
    2017 YZ 250x- Braap
    Sep 2005
    MICHIGAN
    2,027
    Yeah your bike is sweet and that cracked piston is crazy ! At least it was not all bad in the end...
    86 T3
    84 T3
    86 KX250
    May 2011
    The Granite State
    914
    what made you check it out? Noise or just a hunch?
    86 350X ::: 85 250R
    Projects
    350x
    Come and Gone
    86 350x : 84 250r X2
    85 350x X2 : 84 200es X3
    83 200e : 78 ATC90
    O.C., Oregon
    921
    Quote Originally Posted by Super350 View Post
    It died, lost all compression about 5 mins in to the ride.
    2017 YZ 250x- Braap
    Surprise, AZ
    2,428
    I have seen this many, many times.
    The problem happened do to inaudible detonation, (The silent killer) due to not enough octane at that time due to towing a boat anchor through sand.
    To much load and lugging VS. the octane available. I have seen it a Glamis a ton of times...Towing trikes.
    Your engine builder is correct stick with the Pro-X it has a better expansion rate that matches better with the cast iron bore, the Wiseco would have seized solid and probably bent the rod.
    Polish the top of the cast piston lightly, (Don't change the exhaust port timing) it will help with stress risers in the crown casting.
    O.C., Oregon
    921
    I guess that could explain it, I run 100% VP 112 octane race gas but i put a tremendous load on my motor that day in the sand. I will talk to Arlen (LED performance) this week when i take my stuff to him. Thanks for your input onformula1!
    2017 YZ 250x- Braap
    Nov 2013
    brawley, CA, imperial county
    125
    This is good advice as this has happened to my brothers 250r, we were at Olds mobile and my cousins yfz 450 crapped out on him and he tried to tow him back to camp and in about 20min. Into the ride his 250r had the same thing happen as 250rRoostmaster, all power and compression was gone, he tried to kick start it and almost fell over with how easy it kicked foward, he was using an old piston though, rebuilt the top end with a weisco and all systems were a go, hope you get it running real soon.
    Mar 2011
    Grafton, Ohio
    91
    I got lucky also with my CRF 450. Pic below is of a CP piston that was in my bike. Went to start it up after sitting for the winter, and had no compression. Took the motor to my friend to check it out ( normally I would, but was on OT and had a race the next week). When I picked up the motor, that's when he showed me the piston. We both agreed I was lucky, especially since I just rebuilt the entire top end a year prior after breaking a valve. The piston was not new when I got it. The piston and the cylinder came from a guy at Crower cams who did some dyno pulls with it and took it off.Click image for larger version.
Name:	joes folder 009.JPG
    Mar 2007
    Texas
    5,045
    sweet trike sir! O7
    sucks about the piston, but as stated, glad it is an EZ fix and yea i would not be towing anything with that trike ever again. if you need to get yourself a crappy 200-250cc chinese quad you keep at the truck just for towing bikes back. they are good for towing stuff and cheap. or, get a big red
    ________________
    https://www.mikesatvfix.com
