So after way too many hours dorking with my stock 34 mm Keihin, I finally decided to buy a new 38mm Airstriker (thanks for the push yaegerb!). It still isn't here yet, but I know that I will have some fit issues with the boot and insulator which I don't think will be a major issue.
The one problem that I can see being an issue is the "insulator band" that holds the intake insultor onto the carb. Has anyone gone from stock 34mm to a 38mm carb using the stock insulator? If so, did the stock band work or did you have to get another one? Would just a longer screw be enough to make the stock band work?
I just don't want to use a hose clamp from the auto parts store... I know there has to be a suitable replacement from another bike.
Thanks in advance.
