Thread: 85R Intake Insulator and 38mm Airstriker
    Onetrackmind's Avatar
    Onetrackmind is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2015
    Allen Texas
    399
    So after way too many hours dorking with my stock 34 mm Keihin, I finally decided to buy a new 38mm Airstriker (thanks for the push yaegerb!). It still isn't here yet, but I know that I will have some fit issues with the boot and insulator which I don't think will be a major issue.
    The one problem that I can see being an issue is the "insulator band" that holds the intake insultor onto the carb. Has anyone gone from stock 34mm to a 38mm carb using the stock insulator? If so, did the stock band work or did you have to get another one? Would just a longer screw be enough to make the stock band work?
    I just don't want to use a hose clamp from the auto parts store... I know there has to be a suitable replacement from another bike.
    Thanks in advance.
    Surprise, AZ
    2,428
    If I remember correctly the stock one will work.
    You can you a Honda CR250 clamp 1986 & up works.
    Jul 2012
    Joplin, MO
    597
    You can heat the stock one up and it will work. A UPP works too. I have a CR250 intake and reeds on mine. Bolts up but it is a little bit shorter.
    Jan 2015
    Allen Texas
    399
    Thanks guys. Yeah, I know that I will have to heat and stretch both the boot and intake insulator to accept the larger carb. It's just the band on the insulator side that I'm worried about. I am guessing that the new OD of the insulator will be about 51mm and I can only get about 49.5mm ID out of my stock band. I may just try a longer screw and see if it works (no air leaks). Thanks again.
    Jul 2014
    Lloydminster, Alberta
    503
    I just used a longer screw, works fine
    Mixing gas and haulin' ass
    1984 ATC 70 x2
    1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
    1985 ATC 250R-stock
    Jan 2015
    Allen Texas
    399
    Thanks. I went to pick up my cylinder today and killed some time looking through the shop's dead-end project bikes. Found an air boot band off of a CRF150 that looks like will be perfect. Cost?....$0 [emoji106]
    Surprise, AZ
    2,428
    Quote Originally Posted by Onetrackmind View Post
    If you go that route heat the boot in HOT water. Put the boot on the carb & clamp it, then put the boot on the engine. After a while the boot will keep the bigger size and not split, hit it with a little WD-40 so it doesn't crack. (Very old school tip that works)
