I had to take my 1982 honda atc200 big red tire off today. The old tire which was a 2-ply wouldn't plug anymore. I have a 25x12-9 swamp lite tire to put on. The problem is its a 2 piece split rim. The old seal was bad and fell apart when I removed it. I can't get a new front wheel because aftermarket 9 inch wheels with a 4/150 bolt pattern don't have the correct offset. All I could find was an ITP steel wheel with a 3+6 offset. And it was on ebay. Can't get them online on a powersports store. So the dilemma is either to run a seal and pray the tire holds air or run a tube. Tubeless is indeed better as I can plug a hole without removing the tire. Tubes need to be removed and patched. Just want to know what other users do with their split rims. Thanks
