Results 1 to 13 of 13
Thread: Tecate gearing
    Ragar is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2015
    Eau Claire WI
    186
    Tecate gearing
    What Sprockets you all running?
    mines set up 13-37
    My rear sprocket isnt in the best shape. so seeing what you guys run.
    Enumclaw WA
    89
    What kind of riding are you going to be doing and do you have any motor work done? I'm going to try 14/37 on mine for dune riding and mine is a 310.
    Jan 2015
    Eau Claire WI
    186
    13-37 is stock on the T3
    Its gonna do a little of everything. But mostly its a trail machine and alot of its life is going to be ripping up corners and blasting at high speeds on the straights.
    I will likely stay with the Stock gearing, but was curious what that other riders had picked and how it was it was working for them.
    Enumclaw WA
    89
    Hopefully mine will be done in a few weeks and I can see how my gearing works out. I went +1 tooth on my front sprocket of my 350x and 250r and liked it so that's where I am going to start out with the Tecate also.
    Jul 2013
    USA
    737
    I will be running stock sprockets with stock tire height, stock bore. I haven't heard any complaints or witnessed any problems for general riding. Stock gearing always seemed to be fast in first and fast in fifth, lol.
    Definitely been some years ago though. To me it was a pretty nice put-n-run ratio. Have you ever ridden a Tecate before? They move fast! Pretty fast for tight woods riding. Try out the old sprockets and chain if you have them.
    May 2011
    eden,ny
    3,481
    2nd gen t3's are very limited one rear sprocket sizes these days unless you go to an aluminum rear. I run 14/35 with 18" tires so it's probably pretty close to stock gearing.
    Sep 2005
    MICHIGAN
    2,027
    Quote Originally Posted by just ben View Post
    That was my question- where are you buying assorted sizes of rear 86/87 T3 sprockets?
    I searched JT sprockets and found bolt hole patterns that were the same but not the tapered holes themselves.
    86 T3
    84 T3
    86 KX250
    tecaterob is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Miami Fl
    435
    I have 14/36 right now, but will try the others I have when I finish my build. I have front 13,14,15 & rear 35,36,37
    3 86 Tecate 3
    1 87 tecate 3 (with kx 540 motor)
    1 87 tecate 4 (with 330 motor, 250r geometry)
    1 83 atc 70
    1 Kfx 50
    1 kfx 400 ( with 470 parting out bike)
    1 78 KZ 1000 ( with 1340 turbo)
    1 Aprilia SXV 550 Supermoto
    1 01 ZRX 1200 prostreet (sold)
    Buffalo, NY
    1,994
    You can get custom sprockets from sidewinder in steel and other variations of steel. That's your only option for smaller rear sprockets unless you get lucky and find one like ben did on ebay.
    Jan 2015
    Eau Claire WI
    186
    Sprocket Specialists pretty much makes anything for anything in Aluminum or steel too.
    and have... fair... prices lol
    Surprise, AZ
    2,428
    Quote Originally Posted by Ragar View Post
    Correct!
    I use them, many choices.
    http://sprocketspecialists.com/sproc...stroke-zx-636/
    May 2011
    eden,ny
    3,481
    Actually I found 2.
    Jul 2013
    USA
    737
    Quote Originally Posted by tecaterob View Post
    I think the best option is have several sprockets and chains. Although expensive, you will have the right combination for most every circumstance, like racing or keeping up with the R's sixth gear. Making Tecates the main drain, finally will have those sprockets/tire/rim combinations to choose from for many variables and situations. Gives the ability to fine tune and experiment, which for me is the most fun anyway. Good experiences with the aluminum sidewinder sprockets here, I vouch!
