Thread: Recomended bearings?
    dman10's Avatar
    dman10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2013
    Elgin, TX
    402
    Since I'm rebuilding my 200HX,
    I figured I go ahead and replace all the bearings. So front and rear axle and steering neck.
    Anybody recommend where I should get the bearings from? This is a budget build, but I don't want bearings going out in a year.
    Thanks,
    "D"
    Quote Originally Posted by tri again View Post
    Cool stuff seems to happen when I'm sleeping.
    Nice to know things happen without me.
    Aug 2014
    South Louisiana
    1,915
    All balls is always my first choice. Best bang for your buck.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    If you want the best, timken bearings are tough to beat. Auto parts stores should have them, will probably have to cross reference the numbers.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    Jan 2014
    Massachusetts USA
    782
    The trick with steering head bearings is to replace ALL the loose balls AND the races at the same time, or convert to tapered roller bearings (moose or all balls racing are both decent kits). Use the best EP grease you can get your hands on, and adjust them correctly with a little bit of preload (any play is bad). This will all make way more of a difference than the name brand of the bearing. Same goes for wheel bearings- good grease, and make sure the spacer in between the bearings isn't worn, that will affect the preload on the bearings. Follow those recommendations, and keep the pressure washer nozzle away from them when cleaning, and they'll last for years.
    1985 Tri-Z 250
    1985 ATC250R
