Picked this gem up from a guy at work for a damn good price a few weeks ago. I have a pretty big trip planned in a few months and I'd like to bring this as my main machine but it has a few issues. It starts right up, didnt rattle or clunk or anything. zero smoke. great compression. i scoped the cylinder and you can still see all the cross hatching.
#1 in the past week it has developed a rather loud clunking from the bottom end. at idle or riding in first gear it is fine. no noises at all on accel or decel. get into second and it starts clunking, the higher the gear and the faster the speed the louder the clunk. it seems to be relative to engine RPM and not drivetrain speed, the clunk does not get faster with speed just louder. it shifts fine. it stays in gear. it doesnt burn the clutch at takeoff.... buuut.... I have since taken the clutches out, measured per FSM requirements, and inspected stuff. Fibers appear good and measure at ~3mm (manual states 2.8mm wear limit) and the basket looks good. the centrifugal clutch on the other hand looks buggered. i'm getting that the shoes are worn 2x past the wear limit and the drum itself is HEAVILY grooved. also i was able to spin the nut off of the clutch by hand after knocking the keeper tab down! SO. before i go buying a new clutch... what are the odds that that was my clunking? could the one way bearing be bad enough, the clutch be loose enough without the nut tight, and the drum be so worn.... that it clunks like aunder load?
#2 It wont charge the battery. everything stator ohms out fine so my guess is the rec/reg is shot. i couldn't find any test stuff for it in my manual. anyone got any info? also... whats the rating on the charging side of things? The lights are run off a regulated AC circuit. the DC is just for charging the battery. I would like to change that up and run and LED headlight and Taillight. even tho they would be led lights would that be too much for the dc circuit?
so. all in all. I know a timberwolf clutch will work. but.... will a newer one work? like say... a 2008 big bear 250? either way im replacing that clutch, torquing it all down, and praying that was my clunking. thoughts? wana tell me im done? you here jack?!
