Results 1 to 8 of 8
Thread: plastic welding
    Carthage NY 250r rules
    2,355
    plastic welding
    Iv been teaching myself plastic welding. I use a broken fender pieces, heat gun,wood burner tool and a old flat iron for ironing clothing. Iv been practicing on some of my old broken fenders. Heres some of the welding I did on my old 81 250r front fender. Once I get welding figured out I will do some sanding and polishing. I want to get to the point were I can weld,sand and polish and you cant tell it had ever been broke.This fender was crushed so far its coming along nicely for welding. I may weld it up and put it on the trike and take it for a few rides to see how durable the is. I have a bunch of old broken pieces to use as filler. Its a long process.Click image for larger version.
ID:	212375 Click image for larger version.
ID:	212376 Click image for larger version.
ID:	212377 Click image for larger version.
    250r rules
    Nov 2013
    brawley, CA, imperial county
    125
    If this catches on you sir will be very busy and very popular around here for some of us who want to fix plastics instead of replacing them.
    Sep 2012
    Indiana
    460
    I've used this same type method numerous times, but I use a soldering iron. Main issue I always run into is getting black burnt plastic impurities into the weld. So after sanding and polishing there is still an area you can tell has been welded. Seems to hold up well though.
    Freedom Township, MI
    642
    I work at a laser company in which we weld plastic together. We'll actually have a "rib" which is between the 2 surfaces that are being welded. Then that rib is heated up whilst at the same time the 2 surfaces are pressed together using a pneumatic clamp. What I'm saying is you definitely need some sacrificial filler materials (free from impurities) and you might try applying some pressure to the weld. Obviously you're not using a laser but a similar technique may be worth trying.
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    2003 Polaris Predator 500
    1988 Yamaha Warrior
    2003 Polaris Predator 90
    Previous Trikes:
    84 Honda 110 (parts)
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    KX 80 Trike conversion
    Gone and missed:
    Dec 2014
    SW PA
    41
    You need to reinforce the back side of the weld with some mesh. Aluminum or stainless window screen works good. Don't use galvanized screen or it will bleed out over time.
    The blackening of the plastic comes from the heat being too high. Buy a plastic welding iron from Harbor Freight and you won't have that problem.
    Fredericton, NB
    92
    Not that I'm paranoid...but you might want to keep this "fender fix" of yours on the DL.
    Last thing you need, is two beefy guys showing up in black trench-coats on your doorstep...representatives from Zip-Tie International Ltd. asking questions about your plastic welding method.
    I have actually been using Bondic as of late...not on fender plastics, but other stuff. Seems to work quite well.
    Aug 2007
    Montana
    857
    Looking good Donny!! LoL
    DO the Best With What you got !
    My Feed back :cool
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    plastic welding
    Looks good! I attempted to fix a terribly cracked piece of my 200x winter fenders using air filter screen and a torch. Cut and fit the screen, then place on crack and heat with torch oh so lightly and press it into the plastic. Holding great and much sturdier than plastic alone.
    It's nothing pretty but it will work just fine for my cut up winter plastics. I then used goop around the edges and in key areas to help hold it all together.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
