Results 1 to 10 of 10
Thread: 1983 200x gearing With Durablue axle
    Feb 2013
    Walford, Iowa
    120
    I have a first gen 200x with a durablue axle and was wondering where the best place to get sprockets is. I had a 35 tooth on the back with old super turfs and it was geared way to low. If I was to run 20 inch rear tires what rear sprocket would get me close to stock gear ratios with a 13t front sprocket? Thanks
    Trikes Owned:
    1983 Honda 200x - Durablue Axle
    1986 Honda 250r - +2 westcoast
    1984 Honda ATC 70 - Piranha 140 swap
    1983 Honda 200e - Stepdads
    6,811
    Sprocketspecialist.com
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    Or give sidewinder sprockets a call. I run their sprockets on both my 200x and 350x. He gives a good price if you buy new sprockets and chain all together.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    Feb 2013
    Walford, Iowa
    120
    Alright thanks for the replies. I'm probably going to go with a 38 tooth on the back to get me a little faster than stock and a 13 tooth on front. Thanks again for the help.
    Trikes Owned:
    Mar 2007
    Texas
    5,045
    just curious, why a 20" rear? most 200X people want to run a MX style 18" rear for more width and stability. are you planning on lots of clearance issues? if not the 18" with the wider mx style design will do wonders.
    ________________
    https://www.mikesatvfix.com
    Jun 2003
    englishtown NJ
    2,676
    isn't the first gen 200x durablue axles 81-82 250r axles?
    Feb 2013
    Walford, Iowa
    120
    Yeah I believe so since you have to use a 1982 250r rear sprocket with the axle. And I am not really set on the 20s I would just like to keep the chain from being a chainsaw as much as possible. As long as they are mx style 18 or 20 inch and not balloon tires I would run them. What ever I can find a reasonable price.
    Trikes Owned:
    Surprise, AZ
    2,428
    100% correct
    Great shop that supports 3 wheelers, check their website they have everything including some sprocket sizes you will never need.
    The Open Road
    4,736
    I love Sprocket Specialists....bought from them a few times....great phone support too
    I run a 13T front and a 38T Sprocketspecialists rear on my 200X with a Durablue off a 81-2 250R flipped around and running a set of 18`s. I had to use different fasteners as the 250R had a different way of bolting up I think but other than that, perfect fit for this application
    Feb 2013
    Walford, Iowa
    120
    Thanks how do you like the 13/38 with the 18s? I was running the stock front sprocket (12t) with a 35 tooth rear and it was gutless. I could barely use 5th gear with 22in tires on it
    Trikes Owned:
