Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: 250r quick change gas tank
    Jan 2011
    Choctaw, OK
    2,755
    The rear mounts are different. The threaded flange the bolt threads in to is not a through hole. It has a bottom and the threads go all the way to the bottom. This does not allow the ball to extend and lock the pin in place. As you can see in the pic, there is some pin left. if the bottom of the hole was drilled through allowing the ball to fully extend on the other side of the hole then it would be good to go. The hole in the bottom only needs to be big enough for the pin to pass through ( the ball will be retracted going through the hole). The diameter on these pins is .24". It looks like the pin in the pic would be a pretty good length with a rubber grommet on it like that pin is in the previous pics.
    Jan 2011
    Choctaw, OK
    2,755
    Here's a site that has metric ball pins. All you need to know is diameter and grip length.
    http://www.vlier.com/product_index/s...-t-metric.html
    Jan 2011
    Choctaw, OK
    2,755
    Looking at the sizing chart, in order to use the metric ball pins, the threads in the holes would have to be drilled out. A 6mm bolt has an OD of 5.78mm or .22in. The 8mm bolt has a diameter of 7.79mm or .30in. The metric ball pins have a larger OD than the bolt so the treads would have to go.
    ANSI Sizing Chart
    http://www.vlier.com/product_index/s...alllock-t.html
    Oct 2006
    2,504
    WOW, Flyingw that gas tank is shiny and clean!!
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    In my opinion, for this to be worthwhile, the gas tank would need to be able to be removed without any tools whatsoever. If you do accomplish it, how much time is it actually saving you, maybe 5 minutes to remove 6 bolts & a fuel line? I realize it will be a hassle to go through the jetting process on this hybrid engine, but once you've got it jetted correctly, how often will you need to re-jet it? Do you ride in that many different elevation/temperature variations that it will be checked/changed constantly?
    You'd be surprised. The worst part is when you're in super dusty and dirty environments and you can just feel the jetting change from shitted up airfilters and the like during the course of one day of riding. I keep my stuff jetted pretty tight and lean normally, but even with that a hot plug, sometimes when we are idling or going through the woods at the hill climb spot slow, you do a lot of idling and low rpm riding before you actually get to the next hill and have to clean it out good to get up, etc. Having to take the gas tank off in the woods to change a plug when that happens is not an ideal scenario...
    Pulling the tank on the 250R is just one thing I've always found was a bit more cumbersome than it could be, so this is something I've thought about for a lot over the years actually.
    Live Oak, FL
    15,070
    Quote Originally Posted by Flyingw View Post
    Oh no Billy. The ball pins I have are the perfect diameter for the stock threaded holes. No drilling required. The pins are just a tad too long but that can be compensated with a small spring or a round piece of rubber or nothing at all. The fact that the ball end of the pin is long enough to go through all of the brackets, grommets, and threaded hole makes the ball pin a good choice for a quick release. The only requirement on these pins is the ball when locked has to extend all the way out for a firm lock and they did firmly lock in place. You can even put a small leash on the pins and attach them to the lower bracket by way of some small wire rope. I have a whole roll of plastic coated wire rope. I think it like 1/16" diameter. Small but strong stuff. Later tonight I will see if any of the pins I have will work on the rear mounts. I didn't get that far before I abandoned that idea. Now you could also put ball pins of the lower shroud bolt but those are 6mm holes. Smaller than the 8mm holes on the tank mounts. These pins I have are basically 1/4" diameter pins but ball pins are available in all sorts of diameters and grip lengths.
    I'd never heard of or saw these, but I LOVE them already!! I will definitely pick some up and them out.
    The airscoops, I think with some super strong earth magnets, you wouldn't even need a fastener at all there. I've kind had that part figured out in my head for a while, that front mount is the one that is kept me scratching my scalp for a while!
    Surprise, AZ
    2,428
    A lot of sport bikes use a clip style screw they locked in place with a 1/2 turn to hold all the fairings on. They come in hex head styles or flat head screw drive styles.
    They are called Dzus fasteners, they started in the aircraft industry.
    Surprise, AZ
    2,428
    How about Dzus fastners for the two bottom shroud mounts
    [____________spacer|lock washer|wing nut
    And a “Axle” bolt for the front & rear mounts
    (like the rear quick change axle on a motocross bike)
    You can fab it out of steel rod, pig tail the end so it doesn’t turn, drill out the threads on the frame, run a spacer on one end to get it closer to the shroud & make a cool looking wing nut a ¼” away from the outside of the shroud they you can remove it quickly with no tools.
    Quick release the fuel line.
    Jan 2011
    Choctaw, OK
    2,755
    The strength in a ball pin is in its shear, not the pull. As a rule, you don't want tension on the ball but a small amount of tension you would get from a grommet or something soft would keep the pin from rattling but as long as the ball is fully extended, that pin won't come out. Oh, and the pins actually have two locking balls. Send me your mailing addy and I'll drop some of these pins in the mail. I have a couple of parts bins of these pins.
    Jan 2011
    Choctaw, OK
    2,755
    and yes Mr. Clean, that tank shines so bright I have to wear my welding mask when the lights are on.
