Results 1 to 12 of 12
Thread: 350x rear caliper options?
    ejam is offline New to the board Arm chair racerNew to the board
    Williamsburg, Va
    30
    Im helping a friend with his 350x and was wondering if a rear caliper from a trx400ex or 300ex would work on a 1985 atc350x. The caliper body looks the same, just the mounting plates look different. Has anyone tried this?
    Husky250 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2010
    NE Ohio
    264
    Not that you want to go this route but I put a front caliper off a Yami TTR125 on the back of my buddie's gaggas quad. had to make a new mounting plate out of some plate aluminum but that took 20 minutes and voila, brakes were restored!
    Van down by the river
    3,874
    They may be compatible. If you use the search button you will find your answer. You want cheapest way? Cr80 front is a direct bolt on.
    R.I.P. John Swinehart
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    Williamsburg, Va
    30
    thanks for the replies. looks like I will be looking for a cr80 caliper.
    Nov 2007
    Cr 80= easy. Works on 200x also. Plus eliminates parking brake also
    Chris
    Oct 2013
    Woodward OK
    88
    What year cr80 caliper? Found one I'm about to buy that says 96-07 front. Will that work for my 86 350x?
    Sep 2011
    Ocean Beach, CA
    1,333
    81-84 250r front caliper will work with 350x mount plate
    82-84 250R rear caliper will work with 350x mount plate
    83-87 200x front or rear caliper will work with 350x mount plate
    might save you from buying a caliper if you have one of these laying around...
    Oct 2013
    Woodward OK
    88
    Wish I did. Only spare caliper I have is a 200x front. Needing the rear for my 350x
    Sep 2011
    Ocean Beach, CA
    1,333
    thats fine. use that 200x caliper with the 350x mount plate and go ride!
    Oct 2013
    Woodward OK
    88
    I need a rear caliper for my 350x, not a front, and that one still needs rebuilt anyhow. Just need to know what year cr80 fits the rear.
    Sep 2011
    Ocean Beach, CA
    1,333
    the front will fit the rear, theyre interchangeable... thats what im saying. you'll lose the parking brake, but most dont work anymore anyway. if it needs rebuild, it needs rebuild. cant get around that one.
    if you go with CR80, you'll lose the parking brake as well because you can only use the front CR80 caliper. rear is two piston and wont work on your 350x. cr80 front calipers are the SAME as any of the above listed front atc calipers.
    Oct 2013
    Woodward OK
    88
    So the front 200x caliper will fit the rear on my 350x? Are there any other cheap options like the cr80 swap also for the front by chance? I happened to ruin my front caliper this weekend when it fell of my shelf....
