Page 2 of 14 FirstFirst 1 2 3 4 12 ... LastLast
Results 16 to 30 of 204
Thread: 350X baja race buildup
    Mar 2007
    Texas
    5,045
    Thanks manbearpig, I am defiantly buying 2 of everything and defiantly building for dependability. Trying to find a longer travel is not easy for an old trike.
    This project is defiantly a whole new learning expirence for me. I built drag, mx, cx and putter trikes but this is my first go at a Baja build like this.
    ________________
    https://www.mikesatvfix.com
    Sep 2011
    Ocean Beach, CA
    1,333
    Quote Originally Posted by oscarmayer View Post
    Do your research and send some emails to suspension companies. you'll be able to find something
    See you in Ensenada 2016 ;-)
    Apr 2008
    NW, IND.
    842
    Sounds like a very cool project.Are you going to run a larger oil cooler or the dual set up?
    I almost burned up my motor running through a section of huge rocks and root balls the size of cypress trees where I couldn't get out of 1 and 2nd gear for 7-9 miles, had to stop and let her cool down while about 5 miles in.
    Good Luck,update and let bus know how you did.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Mar 2007
    Texas
    5,045
    Running a 3-4Xs larger cooler. That should handle it well. I could even install 2 if I did it right.
    ________________
    Lewiston, N.Y.
    1,479
    Where do you find a bigger cooler?
    Axis makes a great dual spring, dual adjustment for just about anything.
    Yours is a straight mount, mine is a linkage with the 450R rear end on it.
    Pricey, but I'm getting one.....
    Mar 2007
    Texas
    5,045
    eBay!!! . It does. It mount like stock but since this is all mod I going to make a custom mount to bolt to the trike. Let me find you a link to one likened on eBay.
    ________________
    Mar 2007
    Texas
    5,045
    http://pages.ebay.com/link/?nav=item...d=231507525017
    This is just like the one I am using it is 3Xs the stock Cooler size and over double thick. I think 2 of these should do the trick.
    ________________
    Mar 2007
    Texas
    5,045
    ok I got some good insight on some things I can modify to help me a lot. Does someone have a good set of 83-84 250R damper rods for the forks? I need a good set we can use when redoing my 350x stuff. I will tell ya'll later what it helps with once I tested and confirmed. Promise., but for now I just need a set. I'll pay for them and shipping. just need them.
    I will also post in the for-sale section.
    ________________
    Mar 2007
    Texas
    5,045
    Anyone? I really need at least 1 set asap.
    ________________
    Mar 2007
    Texas
    5,045
    I am at work right now so please excuse my questions. Does someone have the dimensions of the headlight shroud for the 350x? I want to see if I can get an led setup that can replace the stocker light sin their sockets or maybe just cut the center of the shroud and put 1 big one in.
    Does someone know the stock Watt rating for the lighting coil tot he headlights? sorry at work and not able to really dig into that right now.
    Thanks for the help guys!
    ________________
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    http://www.3wheelerworld.com/showthread.php?t=173199
    Give this thread a look regarding LED lights for your 350x.
    Head light dimensions are roughly 4.25" wide by 2.75" tall for each light socket or 9.5" from edge to edge if you remove the center bar. Measurements are rough quick measurements using the edges from the front of shroud.
    Stock watt rating is 200W@5,000 rpm.
    Just to give a rough idea of the light bar if used for mine:
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    Mar 2007
    Texas
    5,045
    Thanks a million f76! your a life saver. now to see what I can piece together. today at work is a slow day so I have a few moments to get things going.
    ________________
    Mar 2007
    Texas
    5,045
    well, I pulled the trigger on a lighting setup.
    (12" light)
    http://www.ebay.com/itm/310838283496...%3AMEBIDX%3AIT
    and
    (reg/rect)
    http://www.ebay.com/itm/390964958870...%3AMEBIDX%3AIT
    I decided the headlight shroud is not the most important item. I needed it to work. and this works amazing. I got 2. (1 as a spare)
    my next big purchase is a Trail Tech Voyager GPS computer. (this one)
    http://www.ebay.com/itm/191409820806...%3AMEBIDX%3AIT
    This is the battery I plan to purchase for using.
    http://www.ebay.com/itm/321688433018...%3AMEBIDX%3AIT
    ________________
  15. #30
    Mar 2007
    Texas
    5,045
    Ok some of you wanted to see parts. Here ya go.
    This performance xr400 header fits perfect!!!
    Old axle vs. new billet axle.
    Pile of 350x. This is how it sits currently. Waiting for gusset kit.
    New SS front and rear braided brake likes. My colors are white and blue with some polish. These blue lines will look good and function well.
    ________________
