Results 1 to 14 of 14
Thread: 1982 250R rattle noise, video included
    Winnipeg
    211
    My bro in law has a 82-250r and it has a rattle sound that he cant narrow it down to.. it sounds like top end,
    you decide..
    watch the video and listen carefully.... sounds like piston slap to me..
    https://www.youtube.com/watch?v=Uq5571kDPrg
    thanx for viewing
    Dec 2011
    California
    126
    I have a similar noise but by doing the old long screw driver to the ear trick, it seems mine is coming from the bottom end. Everything shifts fine and runs like a bat outta hell. I'll be watching the tread. These guys are the best at helping out.
    Winnipeg
    211
    yup same with his.. just noisey!
    Slidell, LA
    4,738
    sounds normal to me.
    Winnipeg
    211
    no.. listen carefully and you can hear it
    my 82 doesn't sound like that!!
    Feb 2012
    Pennsylvania
    54
    it has the anti vibe things between the fins on the cylinder right?
    Winnipeg
    211
    believe so
    Dec 2011
    California
    126
    That's interesting... Never thought of those... My 300r don't have them.. Should it? Sorry to jump your thread wpg.
    toki is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2011
    wisconsin
    158
    my 83 does not sound like that either. that thing has a pretty loud rattle... i'd pop the head off and see whats up. seriously. if you've never taken the top end off of one of these you will be surprised how easy it is.
    does it sound that bad while riding or is it worse at idle out of gear?
    I routinely spill Hot McDonalds coffee in my crotch, just to ease the numbness of everyday society..
    Winnipeg
    211
    hes has this thing apart twice now and cant figure out the problem.. first time he checkd top end.. second he took case apart (thought bearings)
    back together and still doin it
    Jul 2011
    wisconsin
    158
    sucks chasing your tail like that....
    only smart ass answer i have is.... ride it HARD. you will find out sooner or later what was clunking lol.
    my guess would be a bearing. maybe one the clutch basket rides on? mine was sloppy and clunked sorta at idle....??
    Miami,Fla.(305)
    808
    Counterbalancer bearngs???
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Jul 2011
    wisconsin
    158
    could be those too certainly. one needs a blind puller to remove.
    Winnipeg
    211
    yeah hes at the point of just riding it till it breaks.. we have parts
