Results 1 to 7 of 7
Thread: XR200 Carb Jetting For 200x
    Feb 2013
    I got a XR200 carb and intake manifold for my 200x
    I'm wondering if anyone else is running this on their 200 and what their jetting specs are so I can start buying any jets I may need as I try to get this tuned in.
    I'm going to be running a stock bottom end and (hopefully) a custom cam, piston , head with large valves and HD spring from Mickey Dunlap
    Also, a DG full exhaust
    Any input/advice would be appreciated
    Thanks in advance
    Apr 2006
    SE CA Dez in the sandbox
    900
    I'm assuming you're going about this in stages? Carb first, then buy the other components? I'll check my carb this evening.
    I'd think that MD could get you close since you are largely going to buy his products. see what he'll recommend. IMHO
    Feb 2013
    It's all going together at once
    I asked him about the XR200 carb but he said he'd never tried it before, which is why i posted here.
    Scootertrash's Avatar
    In the sticks
    4,638
    I'll see if I wrote my jets down somewhere, Id rather not pull the carb if I don't have too.
    I'm running an 84 200S with a Wiseco 10.25:1 piston, XR200 cam, intake manifold, and carb and lightly massaged (cleaned up the casting imperfections in the intake and exhaust, polished the exhaust and matched up the ports and manifolds.
    Slidell, LA
    4,738
    Run a 40 pilot, idle screw out 1-3/4 and needle in 3rd from top. Start with a 120 main and work your way down from there. 118, 115, etc.
    Mar 2007
    Texas
    5,045
    I would start stock and start it and see what happens.
    ________________
    https://www.mikesatvfix.com
    Feb 2003
    Australia
    927
    I think you will find the stock main jet in the XR carb will be 138. If you are doing all those mods at once I'd try it like it is. The XR manifold is the wrong angle and you will have to port your stock one to suit the carb.
