Wow, I have not seen one for awhile. looks like from the bad pics to be about a 1993.
They were decent bikes, pretty fast, reliable, but heavy with harsh suspension & soft springs front & rear, starting was a problem the ignitions were weak, left side kick with a looong kick starter, stand on the left side and use your right foot unless your left handed.
Greg Zitterkopf flew on one in district 37 Gp's and desert races & won the four stroke sounds of thunder motocross title on one.
Throttle cable is stuck- If i remember right the throttle has a push/pull cable.. one of them may be fraid, also check the carb. they used a Dellorto magnesium body carb. and they can cause corrosion and stick to the slide.
Clutch does nothing- I don't know what you mean, does the clutch lever activate the clutch in & out?
dash is missing no kill switch- check with KTM or EBAY.
air filter is gone- they used a Twin Air so I would start there, great filters.
sweet thanks for the info glad you recognize it, uh the clutch i can pull the lever and is goes into gear but even holding the lever in u can not push it forward
i been searching ebay and a few parts sites with no luck
im a big guy 6ft 7 and around 400 pounds so the weight of the bike don't bother me much it will mainly get road ridden with a lil off road once and awhile
here's some better pictures hopefully my phone is real picky about lighting and it's a nasty rainy day
just curious if you know what this second black lever is for? nvm went to the local shop and found out it's a decompression lever
also found out it is a 93 but its a 400 not 600 so maybe finding parts will be a bit easier
go on www.ktmtalk.com, lots of people have them bikes and lots of parts and info.
cool i'll check that out thanks.
"Im a big guy 6ft 7 and around 400 pounds"- I am glad you got off that CR125, this will work better.
KTMtalk is good, lots of good guys there, I am a member.
The 400 & 600 is basically the same bike only bigger cc.
Once you sort it out, they are almost bulletproof and lots of 2-stroke parts fit and many years crossover.
Make sure the clutch lever is adjusted correctly and nothing is hanging up, if it is dig into the clutch assembly and take a look.
yea i had the 125 for about a week i traded a beat up lt230e that leaked oil for it, i though this was a 4 stroke? it don't have an expansion pipe. i was told by a friend that works at a ktm dealer these older bike are impossible to get parts for lol but i see a lot of used parts on ebay just not what i need. if i have to i seen a few clutch baskets on there for $75 + used but i would like to make sure it run's before dumping money into it. some how i need to figure out the kill switch or key wire's and temporarily bypass them
It is a four stroke, what i am saying is many ktms share parts with the two strokes its cheaper that way and makes a better four stroke
Hondas xr and cr shared almost nothing.
ah alright i get it now
You are like the third member of- "Wheeler Dealers"![]()
lol yea i started with a 84 200x and now i have a 6x8 trailer, 95 vmax 600 and a 85 200x auto x conversion lol i miss the tri-z in my sig pic i should of keep that, 1 of the only things i wish i did not trade away.
I love the Tri-Z too, looks like a trade is in order. Get on it!
