is this a good stock carb replacement for an 85 250r?
http://www.ebay.com/itm/Honda-ATC-25...23e284&vxp=mtr
I also have twist throttle.. will I need a diff cable? Also will I need to change jets?
Looks like it might be a China carb, might be ok but I'd buy a brand name myself
doesn't say how big either? 36mm?
32 or 35mm
Hard to say kinda an poor description
86 ATC 250R
86 ATC 350X
86 Tecate
84 Atc 125M
85 Atc 200M
07 Yamaha banshee
Chinese knock-off carbs are sketchy and I would not run one on any of my machines unless I had no other option.
Spend the money and get a Keihin. You know you are getting a quality carb.
http://www.amazon.com/Keihin-016-167.../dp/B00C178JY4
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
That eBay add doesn't say 85 anywhere, it only says 86???? I dont get that? What about a rebuild kit for $30? I would hate to throw $130 bucks away to china just to be disappointed in a crappy carb. Maybe just wait and add a couple more dollars and get a quality carb like an air striker carb? You're half way there. You'll be much happier
'' Mixin gas N haulin _ss''
1985 250R-310
1985 Tri-Z
1985 Tri Zinger-X's 4
1973 atc70
do I have to re-jet that airstriker for my stock setup? stock other than a pipe!
also I have a twist throttle.. do I need a diff cable to hook to that airstriker?
I am not sure about the throttle setup as far as what you need to run the twister.. But PWK carbs (which is what the Air Stryker is) require a different cable than the stock cable on the 250r. ESR sells them as well as a few other 250r oriented shops.
The cable ESR sells is for the thumb throttle: http://www.eddie-sanders-racing.com/...le%20cable.htm
IDK what you need to run the twist. Might be looking at an application for a dirt bike that came with a PWK carb. I don't run twist throttles, so I don't know what to recommend to you on that aspect.
As to jetting: Some shops like ESR and others will "pre-jet" for you based on your engine setup you provide them. This usually will get you in the ballpark. Always check jetting yourself and make changes as needed. It's a good idea to get an assortment of jets along with your new carb. I always use genuine Keihin jets myself.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
Yes what ride red said. That site also has some nice stuff like billet parts that you won't find on eBay.
1985 250R-310
1985 Tri-Z
1973 atc70
actually the stock cable that was used on 85 atc250r works perfectly on 38 a/s and 39 pwk.
did these bikes stock come with a twist? couldn't seem to find one with a standard thumb throttle
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
if you want a twist on these carbs, use a twist and cable from almost any cr125 or cr250, just make sure it uses a kehien carb. Not sure, but alot of yamaha used the same carbs and alot of ktms do also. Infact I use cr 125 cables on my ktm 2 strokes. My 98 200exc uses almost exactly the same as a 38 a/s stock, stock carb on 07 250xc is nearly identical to what is used on a yz250, later year ktm 200's used nearly same carb that is used on many 125's. Kawasaki was the only one to have a twist throttle stock on trikes, 84-87 kxt250's.
Many Kawasaki kx and suzuki rm's have them as well.
Sent from my SM-G386T1 using Tapatalk
I ordered one of these Air stryker carbs.. will the MOTION PRO twist throttle cable hook right up to it?
