So i was back to playing with the 200 es I'm trying to work on. I got the bike running and was going to check the timing but when i unscrewed the timing cap while it was running oil shot all over me and my face. I quickly grabbed a rag and put it over the hole. It kept flinging oil. I couldn't tell if there was any "compression" coming out of the hole or if it was just slinging it. Anyhow im assuming this is not good and that i have some seals bad or something, am i correct? But also for all i know someone may have poured oil in there, although i find that unlikely. Is this a common problem and something that i can repair? What special tools am i going to need? I love spending money.... This all started because i went to set the valves. When i took that cdi cap off the engine there was metal spring chunks laying in bottom of it and in cap. I believe this is the "pulse generator". Anyhow i took another one with good springs from a scrap engine and replaced it so now i figured my timings probably off also now. So go to look in the timing hole and about to go look for the tach and get. Eyeful and mouthful of flying oil. Sometimes i regret my willingness to learn. Im not rich but i know i can afford to just buy a bike like this in good running shape but then i will not have been the "one" to have fixed it and i will have learned nothing. I have learned that there is a reason that everyone selling a bike says "the carb just needs cleaned".
