where do the oil coolers mount?
Anyone running this kit on here yet?
How do i go about re-sleeving my cylinder? Could any machine shop do it? Does it come with the machining specs for the bore?
Mickey what was the HP increase?
Definitely a must have for my 250sx project I will be starting soon. The video of the big red you did blew my mind. Do you have a ballpark figure for the whole thing, sleeve and piston kit, stage 2 cam any headwork needed, oil cooler etc.? Is the 400x carb a direct swap or will any modification be needed to bolt that on? I will be looking forward to getting started on this one for sure.
The kit with piston, sleeve ,head gasket, cam, valve and clutch springs is $610 exchange on the cam, plus shipping. Oil cooler kit is $85. We charge $200 to re-sleeve the cylinder. We ended up using the 300ex carb you can get for about $65 new off e-bay. The 400ex carb was too big.
Safe to say might as well replace clutch plates or at least inspect I'm sure when considering the power upgrade.
79 110
83 185S
84 250R
3x85 Big Reds
85 200X
85 ATC 70
85 Tri-Zinger
86 200x
86 TRX 125
87 TRX 250
89 TRX 300
98 TRX 450S
03 TRX 350
5 Foreman 500 4x4's
You can never have enough! ATC250ES is still the best!
do these require case boring?
________________
https://www.mikesatvfix.com
________________
The 250sx guys are complaining they can't use all the power because the front end won't stay down. That's what I knew with our old 315cc kits, so they work better in the Big Red 250.
