Page 2 of 14 FirstFirst 1 2 3 4 12 ... LastLast
Results 16 to 30 of 201
Thread: Tecate CDI Recreation - For Sale
    Apr 2002
    s.w. michigan
    6,498
    I can recommend some easy to use encapsulation resins when you're ready
    Jan 2014
    Massachusetts USA
    782
    Check these links out- I found them a while back when researching CDI box schematics. They both are for KDX cdi's but would surely get you in the ballpark.
    http://www.dragonfly75.com/moto/CDI.html
    http://www.dragonfly75.com/moto/KDXCDI.html
    1985 Tri-Z 250
    1985 ATC250R
    Wichita, Kansas
    1,361
    Already read through all of his stuff. Looks like good work, and it definitely points you in the right direction.
    I also agree with Jeswinehart. Encapsulation resin. Kawasaki didn't do this just to be mean, they did this to keep any and all things out of the cdi. Moisture mostly. A few hundred volts and you add some rain water...
    You can bake a CDI in an oven at 200 degrees for 10 minutes if you think moisture may be in it. From my reading, this method may work.
    I'm starting on a schematic now.
    phantomtracer's Avatar
    phantomtracer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    392
    Wow, those are great links.
    I need to read that about 10 times before I will ever understand it, but great info.
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    This is one thing (Much like expansion chambers) that has always sort of been a black arts type knowledge, so I find this discussion and research you guys are all doing veeeerrry interesting
    Wichita, Kansas
    1,361
    I've got most of the schematic drawn up for that kx125/250 cdi I took apart. I don't know the cap values. The scr is to old to find a data sheet on so I can't confirm the pin out. I'll be analyzing it more this evening. It should follow the pattern as to what pin is what.
    On a side note. I laid out components to build an ac-cdi. Tonight I'm soldering them together for a test
    May 2009
    S.E. Michigan
    1,251
    What is the SCR part number? I saw in a previous post two you mentioned: F2R5G and F0R2B. Was it one of those you are looking for?
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Wichita, Kansas
    1,361
    F2R5G. I found the other. The F2R5G is the main 1.
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    So i use to use a tecate 4 stator. And it only has 2 coils. not 3. Would this be a better setup useing less wires?
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Wichita, Kansas
    1,361
    The goal is to recreate the cdi.
    If the tecate 4 has 2 coils.. That means the kdx schematic I found should work.
    To clearify* I haven't seen a tecate 4 stator. Is it just a single coil on the stator, no trigger/pickup coils?
    tecaterob is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Miami Fl
    435
    Man I wish I can help but I SUCK WITH ELECTRICAL....
    3 86 Tecate 3
    1 87 tecate 3 (with kx 540 motor)
    1 87 tecate 4 (with 330 motor, 250r geometry)
    1 83 atc 70
    1 Kfx 50
    1 kfx 400 ( with 470 parting out bike)
    1 78 KZ 1000 ( with 1340 turbo)
    1 Aprilia SXV 550 Supermoto
    1 01 ZRX 1200 prostreet (sold)
    Mar 2007
    Texas
    5,045
    you just gave me a headache guys. tanks :P
    LOL
    ________________
    https://www.mikesatvfix.com
    Wichita, Kansas
    1,361
    I got the cdi built, but untested. I forgot which wire goes to the high voltage, which to the signal and which to ground on the stator lol.
    Its been a busy weekend, I'll be checking it against my spare stator tomorrow, solder the wires in place and then test it.
    I got the CDI from John. I confirmed the part number. Its an 84-85 cdi... Now to pull it apart without running the components. Ongoing to test more solvents. Maybe PVC solvent?
    Wichita, Kansas
    1,361
    I performed a couple of test last night. One had expected results. The other was a good sign.
    Kx80 cdi from 79-80 gave a really nice hot spark. Everything plugged right in except the coil. The kx80 has a round end on the coil wire while the tecate has the flat. Other than that, awesome. I didn't test run it do to the lack of a sun.
    My home made, dt125 replica gave me the odd results. Its kind of what I expected. I was able to get a good hot spark.. Twice.
    With the engine cranking, it's not producing/storing enough voltage to create a spark before being discharged. With the tecate having 4 magnets passing that trigger coil every rpm, we can assume that it will have 4 sparks per rev unless controlled.
    With the home made cdi version 1.0, it was discharging the cap with a low voltage. By disconnecting the trigger coil from the cdi, it would charge the cap. Reconnecting it and cranking the engine over allowed it to fire.
    The issue here is it is either firing to frequently, or not creating enough juice. This can be remedied with more windings on the source coil... But I want a plug and play solution to replace the OEM Cdi.
    Tonight, I'm going to start disassembly of the CDI donated by john. It'll take a long time, but I'm not rushing it.
  15. #30
    Dahlonega,GA. (Formerly Flint,MI.)
    787
    The CDI that is headed your way is an '86 CDI. OEM part# 21119-1074.
    Just so we're all on the same page...the '84 and the '86 carry the same CDI part #. The '85 is different. OEM # 21119-1166. What's the difference?
    I ain't got a flippin' clue.
    Let me know when it arrives.
    Rog'
    "You should never smoke in pajamas..
    You might start a fire and burn your face..
    Maybe you should return to Manaugua..
    You could go un-noticed in such a place"
    FZ
    Ass,gas or grass....nobody rides for free!
    Ride free,Brotha. See you in Heaven.
