Results 1 to 14 of 14
Thread: NEED HELP with my Yamaha 175 tri-moto
    Apr 2015
    7
    Smile NEED HELP with my Yamaha 175 tri-moto
    hello I am new to the board and have got 9 trikes and a couple problems and the major one is with my yamaha..
    I got a 175 tri moto 2 stroke and when i start it it will go straight to screaming and when i play with the idle screw or air it wont change.?
    Nov 2014
    KITCHENER ONTARIO
    45
    welcome to the site keifer
    Apr 2015
    7
    thanks for the welcome MRBIGWHEELZ
    Jul 2013
    USA
    737
    Quote Originally Posted by keifer185s View Post
    Might be crud in the carb jets, maybe an airleak at carb boot or intake, throttle adjustment, carb slide return spring, internal air leak. Leak test the motor.
    Apr 2015
    7
    Does the carb have to have an air filter
    Nov 2012
    Waldoboro, maine
    791
    Absolutely should have a filter. Welcome!
    82 250r
    83 Big Red
    85 Auto-x
    If you've done business with me please leave me feedback
    http://www.3wheelerworld.com/showthr...ght=Bren_downe
    Apr 2015
    7
    Will that slow it down and choke it a bit?? Thanks
    Apr 2015
    lebanon oregon
    13
    You might want to check to see if the slide in the carb is down on the idle screw and make sure the idle screw isn't screwed all the way in. That is usually where I start first. Awesomedad
    sanchez's Avatar
    sanchez is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    where ever i may roam
    228
    Start a poll but my vote is moto leaks air
    !!remember the fun is finding the problem!!
    Appearing since '07
    Looking for a place to happen...
    Making stops, along the way
    Jan 2025
    MT
    3
    I just picked up a couple 1982 Yamaha tri moto YT175 2 strokes one was just for parts the other one i just got put together. I got the one to start but the carb was dumping fuel everywhere so i took the carb off and adjusted the float.Now it wont start at all not even with starting fluid i ordered a new carb for it and still nothing. it has great spark still any ideas of what to do?
    6,801
    Might have fuel trapped in the crankshaft cavity, can flip the bike upside down with the spark plug removed and crank it over until it’s all removed .
    Pretty common on 2 stroke motors when the float valve is stuck open .
    Also did you do a compression check ?
    Check the reeds ?
    New spark plug ?
    Jan 2025
    MT
    3
    yes it has a new spark plug, i dont have a compression tester. what reeds do i need to check?
    Jan 2025
    MT
    3
    thats also what i was wondering if it lost compression some how it doesn't feel as tight as i think it should
    6,801
    Go to the auto parts store and buy a compression tester .
    You need at least 100 psi to make it run .
    Google how to use it .
