Results 1 to 15 of 19
Thread: 200x dies when in creek . seem like a temp change does it. thoughts?
    Jul 2013
    mo
    327
    So a few weeks back at a local atv park with a creek that was probably like 38 degrees my 85 200x would die if i got barely half the bottom end in the water. Now first i thought water+electrics was the problem somewhere but she would fire back up after some choking and gassing. But if i got off the thing and tipped the thing side ways so one side of motor was in water and gas it she would stay alive. So today i got out the power washer ,removed the sprocket cover, started it up and laid water hard on all connectors . And there she sits idling perfect. So now im think this dg piped ,kn filtered stock everything else 200x is tempermental to the shock of change in temp. 42 idle jet and i think 110 main. Any help or ideas let me know. Thanks guys
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Mexico
    9,018
    Do the vent hoses on your carb hang low enough to be in the water at that level? Never had the issue, but it's all I can think of aside from electronics. The temp would have no effect till the head was under water.
    It sucks to get old
    NEPA
    7,051
    I assume you were dipping the mag side in the water? I have never seen it on a 3 wheeler. But on sleds. As the stator coils are dying. Lose spark, drag them inside,get spark,and vice versa. Extremely rare,mostly Yamahas. I would clearly think this is connector related,but given my experience,it would not surprise me to be the stator. But,,, the hot oil would keep heat in them for a short period of time. Good one!!?? Let us know what you find. OMH that stator out please.
    Wichita, Kansas
    1,363
    I'd double check the electronics/connections/ corrosion. When you having it running, wiggle your wires. Check your stator resistance, Everything sounds electrical.. Except the carb vent hose theory.
    I just wanna go fast. If you're not first, you're last!!
    Building performance CDIs for the Yamaha Tri-Z, Yamaha Tri-Moto, Kawasaki Tecate, and more.
    Plug and play with brand new timing curves.
    NastyFastParts.com
    You can also find me on Facebook and YouTube under Nasty Fast Parts.
    Miami,Fla.(305)
    808
    Reroute the carb vents up the frame & give it another go. I routed mine long ago right into the headlight assembly.
    It worked for me before....try it & let us know...
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Mar 2007
    Texas
    5,045
    these trikes not "water resistant", none of these trikes are actually you submerge any of then and it will let water into the case, as mentioned vent hoses for carb or worse crank case vent hose, water in the ignition system.
    stop trying to turn it into a submarine. it's a trike for land not in the water. there are many issues with what you were doing that could have caused this.
    ________________
    https://www.mikesatvfix.com
    Jul 2013
    mo
    327
    https://youtu.be/8j5zgFykYS8
    JUMP TO 5:12 AND YOU WILL SEE SOME OF WHAT I MEAN.
    ill check my vent hoses an see where they lay. and i was thinking electrical but my power washer should of killed it . and its not like i dunk it and i never take my x for creek romps but at this atv park you have to cross the creek to get where your going . ill pull a manual and see what the stator is resting at. would the temp change affect stator?thanks for the tips guys . ill keep you informed.
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Mexico
    9,018
    Quote Originally Posted by oscarmayer View Post
    I have to say that my YTM was nothing short of water proof. As long as the water didn't get over the lower triple clamp where the air intake is located you could swamp it all day long. Not so now, I have some sort of electrical issue that makes it sputter after a bath. I should go though it again.
    Anyway, while splashing around the local creek and ditches back in the day there was always a 185s or a Big Red next to me and I don't recall anyone ever needing a tow home.
    It sucks to get old
    Jul 2013
    mo
    327
    ok i just got to run out to the garage between baby duties and yes the vent house head down out between the swing arm. ill relocate them north. ill bring my multimeter home from work and see what the coil is up to. again really appreciate the help guys.
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Jul 2013
    mo
    327
    i really try to keep my beloved x out of the creeks,but sometimes u gota cross em to get to the other side. and ive got my 250es if i wana submarine, but really every time this 200x has to cross water she dies . even last year at a place called brushy ridge in illinois you have to cross a creek to go thru the park and one lil hole that didnt pass the middle of the bottom end killed it. i mean all my hondas can handle some water but this one is ruining riding experienceS which makes me not want to bring her out to play.
    EDIT .... I FOUND WHERE IT ALSO DID IT TO ME AT BRUSHY RIDGE !CHECKOUT MINUTE 3:57 ON THE VIDEO.
    https://www.youtube.com/watch?v=y4aCb7oyYMA
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    NEPA
    7,051
    These are basically submarines actually lol. If you have problems crossing streams, there IS a problem. You'll get it figured out..
    Mar 2007
    Texas
    5,045
    it ain't yellow :P
    ________________
    Wichita, Kansas
    1,363
    My KLT.. when wet the plug would short out to my knee cap at times.. that sucked. Do you have any grease or anything like that on the plug to keep it water tight?
    Something is in the water that shouldn't be. Check for a crack in a stator wire? possibly the insulator cracked and is intermittently grounding out.
    NastyFastParts.com
    Mar 2007
    Texas
    5,045
    I swear you better paint that dam thing yellow!!!! :P
    ________________
    Dec 2014
    Redmond, Oregon
    38
    Air cooled engines can react in weird ways when the hot cylinder head gets quenched with water. It can have such a dramatic cooling effect that it can change the temperature inside the combustion chamber, and make your engine act as if its just been started cold. This effect is usually only temporary. I have had this happen with my 1986 xr600r in water crossings. As soon as the cold water gets splashed onto the cooling fins, the engine idle drops, and throttle response suffers a bit until the head temp. recovers a little. My XR does not have any electrical problems, and will not ingest water unless it is above seat height. This might be parts of whats going on, but your engine definitely sounded like it lost spark during the video.
