So I've got one wheeler almost together. If I hold the plug against the motor I've got spark, but if I hold it a little ways off then I don't have spark. The other odd thing is that with the plug against the block I don't see any spark at the points but with the plug off the block or in the hole I see spark at the points. I've been told that it's a bad ground between the motor and frame, I've also been told it's normal. Not really sure what to do cause I can't get the motor to fire on spray. Does anyone have thoughts on what to check or what to do? Thanks for your time and advice!
