Thread: dumb serial number question?
    Jul 2014
    Illinois, United States
    79
    Exclamation dumb serial number question?
    Hey guys. So on my 1984 200s frankentrike, I noticed today that the gear order is opposite of what it says in the owners manual. It says in there that neutral should be all the way at the bottom. Contrary to that, neutral is all the way at the top on it. This is how it is on my '83 185s, which the owners manual for that trike agrees with on. This made me wonder if the engine might be unoriginal, as there are several other unoriginal parts on this trike. The forks are unoriginal, the gas tank is unoriginal, and 1 of the rear rims. I'll post some pics below. Anyway, so my question is, how do I decode the serial number on the engine? I tried the VIN decoder on the website and couldn't figure it out. it was telling me all of the numbers I tried were invalid. I have the serial number on the engine, and I found the sticker on the steering column but I didn't see a serial number there for the frame. Ive got a pic of that but not of the engine serial number, if anyone wants to see that I can take a pic of it. Any help? Thanks.
ID:	215392Click image for larger version.
ID:	215393Click image for larger version.
ID:	215394Click image for larger version.
    3 Wheelers:
    1983 Honda ATC 200E Big Red "The Barn Find"
    1984 Honda 200x with 200s engine "Auto-X"
    1981 185s junker SOLD
    1983 Honda ATC 185s "the original" SOLD
    1984 Honda ATC 200s "The FrankenTrike" SOLD
    1984 Honda ATC 200s "ole reliable" SOLD
    1986 Honda ATC 200x SOLD
    May 2009
    S.E. Michigan
    1,251
    In 84, the shift patterns for the 200ES, the 200S, and the ATC70 (that I know of) had Neutral all the way up. So, to shift into higher gears you pressed down, back to Neutral you lifted up. The way you describe it working sounds right to me for 84. This is backwards compared to a lot of the machines from other years (250sx, 250ES, ATC70 for 85).
    To confirm your engine year, grab the serial number from the engine itself, but given your shift pattern I'm pretty sure it's 84.
    This link will let you correlate your engine serial number to the year:
    http://www.3wheelerworld.com/showthr...Serial-Numbers
    Last edited by wonderboy; 04-29-2015 at 09:30 PM. Reason: Added post with engine serial numbers
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    May 2009
    S.E. Michigan
    1,251
    ...and your frame serial number is on the left side of the steering neck.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Jul 2014
    79
    Ok, thanks. The only reason I doubted it being an 84 is that in the owners manual for the 1984 Honda ATC 200s, it says the gear pattern is opposite of what you described, and also is opposite of my 83 185s. I know the frame is from 84, it says that on the sticker up by the steering neck so I don't doubt it at all. As you see in the pictures, it has the pre-82 style front forks, from an ATC 200. I would not have doubted if one of the previous owners had pieced it together, using the forks and engine from 1 mixed with the frame and everything from another. I also noticed it had the tank decal from an 85 200s, however it might just be that somebody changed the decals for whatever reason. Thanks for confirming what I kind of suspected before but wasn't sure.
    EDIT: Found out the confusion. The owners manual I have on my phone is for the 85 200s
    3 Wheelers:
    Pacific NW
    4,255
    I think they changed the shift direction for safety?
    I've climbed on a running trike and stepped on the shifter by accident and it jumps fwd.
    With neutral all the way dwn, that almost can't happen.
    Never have figured out what years / models or when they changed them.
    Having some of each if downright confusing.
    I like the old british bikes.
    shifters on the right where most m cycles had the brake.
    Jun 2014
    Pittsburgh
    107
    The 10th digit in the vin number will be an "E" if its an 84. If its a D its an 83 and if its an F its an 85.
    '' Mixin gas N haulin _ss''
    1985 250R-310
    1985 Tri-Z
    1985 Tri Zinger-X's 4
    1973 atc70
