Thread: Oil Leak from Pull Rope Cover
    Nov 2014
    Angier, NC
    4
    1983 and 1984 ATC200
    Both trikes have oil leaking from the bottom of the pull rope assembly / cover. I have already replaced the large o-ring in there and the small one, too. Double checked they are installed correctly.
    I guess I need to get the gasket for the cover itself. However, if I gasket the cover with the o-rings leaking, won't I just accumulate oil inside that cover? Would I need to drain it periodically? Or would the oil flow back into wherever it came from??
    Sounds like the crank seal is bad behind the flywheel
    Dec 2012
    812
    Quote Originally Posted by big specht View Post
    That's exactly what the problem is. I've had to replace this seal on 2 of my trikes already. No leak in pull start cover after that
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Cold Lake, Alberta, Canada
    3,013
    Quote Originally Posted by kckranz View Post
    X3 on the seal. The gasket itself doesn't do much except for dust control. Theres a small weep hole at the bottom which is where your oil is coming from and is there to drain water from your pull start assembly.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Nov 2014
    Angier, NC
    4
    The crank seal that you refer to, do you have a part number for it, a link to a diagram that includes it, or the technical name for it? I cannot find it in the shop manual or in any parts diagram online. Is it a true oil seal or an o-ring? I take it that the flywheel needs to be removed if you say the seal is behind it.
