after market carb
I just installed a after market carb on my 84 200 es--it's a good fit and is identical to the old one.
the problem is I cannot get it to idle--it starts fine but will not idle--it starts at almost full throttle.
I tried to adjust the idle screw with no change- where did I go wrong.
you have the throttle slide in backwards. unscrew the throttle out of the top of the carb and put the slide in the other way.
That's what I was thinking but I was not sure--thanks for the easy fix.
//ArrowChat Integreation Code
