Results 1 to 15 of 24
Thread: 185S Blown Head Gasket
    Jan 2011
    Choctaw, OK
    2,755
    Hey guys,
    I recently rebuilt an 81 185S including the motor. The motor was in great shape but somebody at some point put a Wiesco high compression piston in it. The cylinder was still round so I ran a hone through it and put it together. I used a run of the mill gasket set for assembly. I sent it home and they have ridden it. This weekend at the Rampage it started blowing cylinder compression out the head gasket on the right side but not every stroke???? It is intermittent when it is reved but it doesn't do it at idle. Strange indeed.
    My question is...... Whats it worth?? Just kidding.
    Is there a different head gasket I should have used with the high compression piston?
    Mar 2007
    Texas
    5,045
    Stop using junk gaskets and how did you torque down the head? If you did not properly torque it down the it will blow any HG. Use oem gaskets when possible. At lease for the HG. Cosmetic is the #2 on my list when I need a good one and oem is not available.
    Check timing and valve lash. Those can all have an effect. Was the piston peeped prior to install? Sharp valve relief edges or dome edges can cause detonation. I would pull the piston and take a cartridge sand roll and take all those sharp edges. Small file could work followed by Emory paper to smooth. Run Emory across the entire top to take off matching marks and polishing.
    Good luck. Of done right hi comp will last w/o issues for years. I have a 200x with 5 years and tons of hours on it with a 12:1 wiseco and ran perfect.
    ________________
    https://www.mikesatvfix.com
    6,810
    If you can find a copper head gasket that would be best and if it's a wiseco 12:1 piston it's a must but if it's their 10.25:1
    An oem or generic should hold up fine also take note of the bore size most gaskets are for 65mm stock bores and a 66mm over bore might be to small .
    Jan 2011
    Choctaw, OK
    2,755
    Yes Oscar, the head was torqued. I didn't install the piston originally but it was in beautiful shape. The reason for my post is I read some posts suggesting a different gasket is required. I checked Weisco's web site and the only note I saw for the ATC was on the ATC 200 engines, 92 octane is required to avoid detonation. I haven't pulled the motor apart yet confirming the blown head gasket but 'm pretty sure that is the problem. I'll get back with you guys when I get it apart.
    Mar 2007
    Texas
    5,045
    I believe the Honda xr125 is the same but in a metal material and much better. Try one of those instead.
    ________________
    Pacific NW
    4,255
    I want to know the intermittent part of the story.
    Detonation of oddball timing changes could change fire time.
    Wishful thinking is spastic compression release?
    This is an over the phone (customer) diagnosis?
    Hope it's easy for you.
    I too have a hi comp 200 and simply don't ride it.
    Very hard on ropes and shoulders but roll starts ok.
    Jan 2011
    Choctaw, OK
    2,755
    I was there with it. I fired it up and it ran normally. When I hit the throttle it would puff out the right side but not every time. I agree its strange so I am curious when I do get it apart.
    Oct 2006
    2,504
    I think the issue is you have too much random stuff on the bench with that motor. That is NOT like you at all, you need to get better organized. Thanks.
    Jun 2009
    Leander TX
    2,217
    Jim, did you polish the impact guns?
    Jan 2011
    Choctaw, OK
    2,755
    Oh come on.... I'm not that bad.... I think.
    Mar 2007
    Texas
    5,045
    Honestly in my own experiences, the stock studs can wear out from use and age. You may have an issue of worn studs and they can no longer hold at stock settings. Look at maybe adding 5 to the stock Honda torque spec and see if that helps. Get the XR head gasket from Honda and that should work. That is what I run. That and cometic only.
    ________________
    Slidell, LA
    4,738
    X2 on metal or copper head gaskets.
    Jan 2011
    Choctaw, OK
    2,755
    Copy that Mike. I'll get one on order this evening. We still on for this weekend? Disregard what I said about it being hard to start. Open the throttle just a tad and it busts right off. I took it to the ride this past weekend and it ran like a champ.
    Jan 2011
    Choctaw, OK
    2,755
    Is there a specific year gasket I should be looking for?
    Pacific NW
    4,255
    New bolts please.
    We've had a epidemic of bvroken bolts from fatigure.
    Ai await anxiously for the answer.
    ssss NOT the comression release?
    (i still need a new keyboard but no sympathy)
