Results 1 to 9 of 9
Thread: Any pics of installed inverts on 85/86 250r
    kevin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2011
    Manitoba
    172
    Looking at doing an invert swap on a budget and wanted to see what other guys have done or are doing. If you have any pics of a swap than feel free to post just wanted to see the different options.
    Thanks
    Las Vegas, NV.
    2,532
    Mar 2011
    Manitoba
    172
    Thanks that was a good read. I seen somewhere that they were using triples of a vtx1800 but haven't heard of how they handle. If it's a good proven setup than I think that's the route I'd like to take. I have the vtx triple but having a hard time locating a set of ktm forks
    Las Vegas, NV.
    2,532
    Quote Originally Posted by kevin View Post
    I know Kasey, here on the boards, has used the VTX triple clamps on a few of his 3-wheelers, and I don't recall him complaining of any handling issues. For the KTM forks, they pop up on ebay fairly frequently. Good luck.
    Oct 2012
    WI
    499
    Do you guys with inverted forks beef up the frame? Being that the inverted forks don't flex like the OEM forks do..
    1983 ATC 200x
    1982 ATC 250R X2
    1983 ATC 250R : Future build
    1985 ATC 250R : Main rider
    1985 ATC 363R Duner
    1985 ATC 250R X2 : Future build
    1986 ATC 250ES
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    Quote Originally Posted by hatc200x1 View Post
    Ugh. I wish this fallacy would die.
    Every single broken frame I've heard of on a 250R in the last 10 years has been one bikes with STOCK forks because they bottom and beat the hell out of everything else.
    Live Oak, FL
    15,070
Name:	_CPB1963 (Large).jpg
ID:	215791Click image for larger version.
Name:	_CPB1974 (Large).jpg
ID:	215792Click image for larger version.
Name:	IMG_0923 (Large).jpg
ID:	215793Click image for larger version.
Name:	IMG_0928 (Large).jpg
    Oct 2012
    WI
    499
    I believe Jacob has had his frame gusseted. I agree that the biggest issue with frames breaking is because of bottoming.
    1983 ATC 200x
    1982 ATC 250R X2
    1985 ATC 363R Duner
    1986 ATC 250ES
    Live Oak, FL
    15,070
    Yes of course his is and I wasn't using it as an example as a frame that hasn't broke, but as a picture of a bike with them.
    Again, every frame I've heard of breaking in the last 10 years has had conventional forks. every single one of them. So what if the inverts "don't flex" they also provide a better bottom resistance than a stack of bricks which is the real problem
