Ok having a runnability issue on my 125.
Just stripped down the top end and had it honed out and put new gaskets and rings in it. Carb has been cleaned multiple times. But now a new issue has started.
It starts up perfect and idles great! Can rip on the gas and revs perfect, but once you put it into gear it goes to hell. If you go past 1/4 throttle it bogs out but you can feather it up to a slow speed and get it into second. It seems to run better when you turn the mixture screw in, running lean?? Has a 200 main in it and has a brand new uni filter and runs on premix. Help!
