Thread: Blater Brake Conversion?
    Feb 2003
    100
    Hey guys, does anyone out there know if hydraulic brakes for a Banshee can be adapted to a Blaster with out a ton of fabrication. I don't mind fabricating a few brackets, just curious if anyone else has seen this done. Thanks.
    Rittman, Ohio
    6,276
    If you change spindles, hubs and brakes Banshee or Warrior will bolt right on, but then your upper A-arm is too short, and you need to either fabricate an extension, or get an aftermarket upper a-arm with the adjustable ball joint.
    Feb 2003
    100
    Thanks for the info.
    Dec 2002
    Missouri
    946
    If you put a Banshee axle and Rotor on the blaster it will be solid mounted. Then you fab up some mounts to mount the Banshee caliper and used the rear system off the banshee.. I think you could do it pretty easly.. Im gonna do that with mine once i get it runing..
    06 TRX450r , 85 ATC250r, 01 TRX300ex, 84 ATC110
    88 Mustang GT
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Why dont you guys check out www.trengaracing.com these are the leading blaster guys in my opinion, they have front and rear conversion kits.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Dec 2002
    Missouri
    946
    Quote Originally Posted by Tri-Z Pilot
    Those brakes cost WAY to much.. you can make them urself for 1/4 the money and it will work just as good or not better.. Ive heard of people riping off the thing that holds the Cyleder on.. it sticks out to far..
    88 Mustang GT
