Hey , if this has been covered somewhere else just let me know ...I tried to find it but had no luck...Ok the problem is I'm building a ATC 500r..the sprocket don't line up to the sprocket on the axle....Where did I go wrong? the engine is centered in the frame...it's in a 85 ATC 250r setup..I have looked at pictures of others and can't tell if this is a common problem or not ...do I use a special countershaft sprocket..or have to make one or does the engine have to be off center... I am almost done with the build never even thought of this problem ..Please Advise
