Thread: how do you remove the seat on an atc 110?
    May 2015
    NW florida
    3
    I'm fixing up a little atc110. having a problem getting the seat off. the lever on the right of the seat unhooks, but doesn't unhook the latch (if there is one) on the left side.
    left side has a larger air snorkle preventing me access to seeing if there is another lever on that side.
    Connecticut
    1,605
    Maybe push down or pull up on front of seat and wiggle a little as you move release lever? Lube the mechanism up with WD-40 to help.
    Welcome to 3WW!!
    Jan 2011
    Brazil, Indiana
    2,087
    Grip it and rip it!!
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Mar 2013
    Central PA
    2,362
    There is just the one lever on the right side. Pull that back, the seat will lift up tank end first, then you can pull the seat and fenders off. Same as a 200x if you have ever had one. Like these guys said, something might be stuck and you might need some penetrating oil to free it up.
    If you download a manual there is a diagram showing the whole mechanism.
    May 2015
    NW florida
    3
    Thanks. The snorkle for the air filter was keeping the latch from coming loose. unlatched left side from below ,then it came up with no problems.
