Results 1 to 2 of 2
Thread: tecate MOTOR #'s????
    Apr 2003
    Dodge, Nebraska
    168
    I have 3 tecate motors! The #'s on 2 of them just read KHI and then nothing!! doesn't looked ground off or anything. And the third has KHI then a lomg line of #'s. Whats the deal with the two that don't have #'s. how else can you tell the difference in the 84&85 t-3 MOTORS??? I can spot the difference in the frame but what about the motors?? :?: :?: :?:
    NICKG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    381
    what you probably have is some engines that had the cases replaced, it was very common on these, as you have to buy them in pairs.(can't buy 1 side seperatly) the 84 and 85's are basically the same, they had slightly different clutch plates, shift forks and a few other things
