Results 1 to 15 of 16
Thread: Harbor Freight Mini ATV Tire Changer (Works for ATC?)
    Oct 2013
    Simi Valley, CA
    22
    Anyone have recent experience with the Harbor Freight Mini ATV Tire Changer on an ATC rim? I saw the older post with mixed reviews but nobody seem to say whether it worked with ATC rims.
    All the shops around here want $30+ to change out a tire and now I have 6 to contend with at any given time. It'd be nice to know if this worked before I grind my knuckles.
    Thanks,
    Scott
    Jun 2009
    Leander TX
    2,217
    I don't know about the mini tire change but I have the regular HF tire changer. Item#69686. It works great on ATV rims.
    I used it to:
    Break beads on my TRX and ATC 70 rims (2 piece, 7") - this alone was worth the $40.
    Break breads and remove junk tires from 1 piece 11" ATC350X aluminum front rim
    Break breads and remove junk tires from 1 piece 10" Tecate steel (84) rims
    Break beads and R&R tires from the 15: aluminum LS mesh rims on my Civic so I could bead blast them.
    I sunk some anchors into my garage floor and mount the changer to the floor when I use it.
    I boxed in the bead breaking "shoe" because it looked flimsy.
    Oct 2013
    Simi Valley, CA
    22
    Sounds like a winner. And you use it to dismount and mount the tire on the rim as well?
    Thanks for the info.
    Scott
    Jun 2009
    Leander TX
    2,217
    I used it to mount/dismount tires on the 1 piece rims but not the 2 piece.
    2 piece don't have the drop center to allow removing over the bead so I just break the beads and unbolt them and slide them out.
    Jan 2014
    La
    1,062
    really 30 dollars the shop around here only charges 5 to take off and 5 to put back on.
    Oct 2013
    Simi Valley, CA
    22
    I got quoted higher than $30, that was the low-end. They want to make it worth their while I guess.
    Maybe if I show up in person at a few shops they'll help me out. If not I'll try the Harbor Freight changer. It'll pay for itself right away.
    Thanks again for the info. JB.
    ps Here's a shot of the 'balloon' tire on there now. 30 years worth of expansion!!!
    May 2015
    Saint John, NB
    64
    Yea shes a little puffed out there lol
    devore,ca
    1,016
    They charge $15 a wheel to change atv tires here in so. cal. I bought the harbor freight tire changer (the regular one) for $30 bucks. It paid for itself on the first set of tires. You have to bolt it down to the floor to get it to work right. There is some room for improvement on it though, just like everything else from Harbor freight.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    6,797
    Oct 2013
    Simi Valley, CA
    22
    The bead breaker is kinda cool but I wish it were $50 or even $75 and came with tire spoons...
    Surprise, AZ
    2,428
    Oscar mayer just sent me a mint 350X front wheel, it had a rotted tire on it so he told me he takes them to discount tire and they charge 6 bucks, I think for that kind of money I wouldn't mess with removing another tite myself and save the shop room
    Apr 2006
    SE CA Dez in the sandbox
    892
    Quote Originally Posted by BOB MARLIN View Post
    I bought the 39.99 Harbor Freight manual tire changer and a pr of spoons after the "professional tire Shop" dinged a flawless 350X rim dismounting the original tire.
    I've been changing my own ever since, and couldn't be more happier.
    Oh BTW, I use it on the two piece rims also.
    Have '85 350X-XR500 Hybrid,
    Had Nicholson framed: 90/110, 185s, Gen I 500, Gen II 500
    Had Bandito Framed 90
    Have Vey's Framed 90
    Have too many parts
    DDQ's Avatar
    DDQ is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2015
    Aberdeen, NC
    414
    I built this one for free using scrap metal I had laying around. Anyone with basic welding skills can build one.
    Apr 2006
    892
    That will def work, good idea.
    Have too many parts
    Oct 2013
    Simi Valley, CA
    22
    That is a cool idea and I especially like that you can plug it in the receiver hitch. Brilliant.
    I went to the local used tire place and they mounted my new Scorpion for $5. Call it $10 with the dismount of the original. It took them all of 3 minutes total with the machine and no swearing or busted knuckles were needed.
