Results 16 to 30 of 51
Thread: XR 650L project
    Jun 2013
    Oceanside, CA.
    612
    Price sounds fair, turn around time good too. Do a little flushing while the cylinder and clutch cover are removed. Whats the plan for cam and rocker arms? As mentioned above still inspect sprocket countershaft splines, any signs of wear or the sprocket needs replaced buy a XR650R they are a tad thicker helps reduce the spline wear from rocking.
    "HJ" Click image for larger version.
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by HairyJR View Post
    Roger that, I have flushed it a few times with diesel. I did the oil tank as well. I found a stock cam on ebay for $65 that looked brand new. It was shipped in a Hot Cams box, im assuming that the PO bought the bike and immediately modded it. I got all of the rockers brand new still in the package and installed them in the valve cover as soon as I got them. I have OEM sprockets new in the package that I will be installing soon, although I may consider the 650r sprocket now that I know of the width issue. The countershaft did not look worn but did have a fair amount of rust on it as did the outside of the spark plug. I don't think the original owner had it under cover very much. Have any of yall used this lowering link?
    http://www.ebay.com/itm/171783381966
    All of the reviews are good and it looks solid. I like that its adjustable. Im a short coonass 5'8" #185, so i will likely need one.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Aug 2014
    South Louisiana
    1,915
    Forks and shock are being sent to onformula1 for lowering upgrade.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    May 2015
    San Diego, CA
    1,797
    That's some heavy damage. I had over a 100,000 miles on my DR before the cam chain broke and it still didn't look like that. That's going to be an awsome bike when done though.
    Aug 2014
    South Louisiana
    1,915
    Started assembling the motor tonight. It's the biggest one that I have ever done.
    Its definitely not a 200x. It moving along fine though!!!
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Aug 2014
    South Louisiana
    1,915
    Motor is assembled and torqued to spec!!!
ID:	217769Click image for larger version.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Aug 2014
    South Louisiana
    1,915
ID:	217940Click image for larger version.
ID:	217942Click image for larger version.
    I'm about to fire her up and do couple of cycles. When the custom suspension returns this baby will already be plated bayou state registered. I'm so psyched!!! I think I have more fun building than riding!!!
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Aug 2014
    South Louisiana
    1,915
    It didn't come with a tool bag so I gave it a trunk!!!
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Surprise, AZ
    2,428
    I hope you used that manual I sent you.
    Clean that nasty seat cover with lacquer thinner on a soaked rag, watch out it will get very clean, but will take off the "Honda stencil" which maybe a good thing. It will also take of that shine and keep your bum from sliding around.
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by onformula1 View Post
    Mil, you're joking right? It has been my life book as of late.
    As for the seat, I began to clean it, but it also has 2 nice size tears in it. So I folded and got a cheap cover for it.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Surprise, AZ
    2,428
    Wow, you are the first person that I know of that actually printed the manual out that I sent them and a 3 ring binder too boot!...Nice!
    Aug 2014
    South Louisiana
    1,915
    Not perfect by any means but I am pretty happy with the results.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    May 2015
    San Diego, CA
    1,797
    It looks good to me in the photo....good job.
    Mar 2008
    EastGreenbush, newyork
    3,494
    love mine. its a beast for sure. I just went to a 14/48 sprocket set up, it was harrowing to ride in the tight tech stuff with the stock set up. if your sticking mainly to roads stock is fine. I am 6'1 and am considering a link! its a tall ass bike, i am on tiptoes level at a stoplight.
  15. #30
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by aldochina View Post
    Holler at Milner (onformula1) he will customize the stock suspension for you. He knows his shiit and won't rape you on the cost.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
