Results 1 to 2 of 2
Thread: 82 185s
    Jun 2015
    Edson Alberta
    6
    82 185s
    Hello there! Ive been again bitten by the atc bug and also bought a large property so I have lots of places to ride. I picked up a 1982 honda 185 with an 83 front end on it. Ive been tinkering with it and need to change a couple gaskets around the head sometime soon as they are starting to seep a little. I was wondering if there is anything i can swap out to add a bit of tourque as i just put some basic 25 inch knobbies on the rear. Its geared 11/41 and i cant find a 10 or 43 sprocket match up with the new way-too-comfy-to-take-back-off tires so maybe i can swap parts for more power. Wondering where to start. Thank you for your time
    daddy420big is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2014
    benton
    302
    if you are goen to pull the top end off you should swap a 200s or 200x top end in it . and a 200x carb and i have a 49 tooth rear sprocket to and the 200s top end
