Results 1 to 15 of 17
Thread: I need your help- 1986-87 Kawasaki Tecate shock length eye to eye?
    Surprise, AZ
    2,428
    Looking for box stock, no aftermarket seal heads or aftermarket shocks, please.
    Thank you in advance, Milner
    Sep 2005
    MICHIGAN
    2,027
    it is around 14.25".
    86 T3
    84 T3
    86 KX250
    tecaterob is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Miami Fl
    435
    Im going to send you mine next week Milner. Email me your address and info.
    3 86 Tecate 3
    1 87 tecate 3 (with kx 540 motor)
    1 87 tecate 4 (with 330 motor, 250r geometry)
    1 83 atc 70
    1 Kfx 50
    1 kfx 400 ( with 470 parting out bike)
    1 78 KZ 1000 ( with 1340 turbo)
    1 Aprilia SXV 550 Supermoto
    1 01 ZRX 1200 prostreet (sold)
    Buffalo, NY
    1,994
    I'm not sure if this info is needed, but since it's fresh in my mind I'll share. The stock spring with a +2 swingarm was a little too weak so with the new +3 I decided to address the issue. First I looked into a works shock, but $800 for a shock without compression or rebound adjustment seemed way too much. I called axis and ordered a 325lb spring to fit the stock shock, I believe stock was 200. They had the spring in stock, it's the same diameter but is 9/16s shorter than the stocker. I was going to get a 300lb shock but due to the shorter spring I figured I'd bump up a little so I have more wiggle room with the preload if it was too soft. So if you need a stronger spring, give axis a call
    Arizona
    843
    If memory serves me right I don't think the stock spring is 200 lb/in. I replaced my stock spring years ago and measured the stock rate at 300 lb/in. I weigh 220 lbs. and replaced the stock spring with a 400 lb/in Hyperco. I installed it on my 87 with a +2 Calfab and it works great.
    Buffalo, NY
    1,994
    The manual says 199lbs initial spring preload. You've eased my mind though, I was worried that the 325lb spring would not work well with the stock shock. Has the shock held up well?
    Sep 2005
    MICHIGAN
    2,027
    I looked at my other shocks and I would say most of them are about 14" eye to eye and one is maybe 14.125" for some reason. Sorry for the previous dimension. As far as what seal heads are in there, I have no clue.
    86 T3
    84 T3
    86 KX250
    Surprise, AZ
    2,428
    Nd4speed
    Thank you for your help
    Sent from my SM-G386T1 using Tapatalk
    phantomtracer's Avatar
    phantomtracer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    392
    I just measured 14.125"
    When I rebuilt the shock I forgot to measure, upon assembly you will find out that the rebound adjustment will not work smoothly if the measurement is any tighter or looser. Verify that the rebound knob is turning smooth and you know it's right.Click image for larger version.
    In that photo you can see the teeth need to mesh just right.
    Surprise, AZ
    2,428
    Quote Originally Posted by phantomtracer View Post
    Thank you, I have the set up tool for the rebound rod
    I was just trying to get a good lenght of a stock 86-87 Tecate shock to see if there are any good alternatives that look similiar or off a different year or KX/KDX
    Those shocks are rarer then hens teeth especially a good one
    Billy Golightly's Avatar
    Live Oak, FL
    15,068
    www.hypercoils.com for all sorts of springs whatever size length and spring rate you could imagine.
    Surprise, AZ
    2,428
    I have a 1985 Tecate shock thats 14.125 inches, can anyone check the width on the top and bottom mounting points and the bolt diameter? For a 86-87 Tecate
    Sep 2005
    MICHIGAN
    2,027
    some measurements for you.......... the first one is width of the bushing. Forgot the bolt diameters
    Attached Thumbnails Attached Thumbnails P1040110.JPG   P1040111.JPG   P1040112.JPG
    86 T3
    84 T3
    86 KX250
    Surprise, AZ
    2,428
    Quote Originally Posted by nd4speed View Post
    Thank you very much!
    Nice caliper by the way, I have the same one, but it's much older about 1990, still going strong! Best money ever spent.
    Oct 2008
    Miami Fl
    435
    Shock is being tmw...
    3 86 Tecate 3
    1 83 atc 70
    1 Kfx 50
