Thread: Ytm 200 front rim/tire.
    Yamawheeler's Avatar
    Yamawheeler is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2014
    Regina, SK, Canada
    225
    Hello gents and ladies. Iam in the process of building a mean ytm 200 and want to know if there is a 10" or 12" rim swap for the front of these bad boys.
    Nov 2014
    Regina, SK, Canada
    225
    This is why I want a bigger front rim.
    Nov 2013
    Paulding County, GA
    91
    You could always swap a tri-z front end on, they came with 12" rims. Your little 200 gonna spin them tires? Is that the shaft or the chain 200?
    -Connor
    Nov 2014
    Regina, SK, Canada
    225
    Shaft model. Works good but clutch kept slipping so I put the engine in shop. Port and polish cam and spring kit valve job high compression piston 20 over and clutch kit. Performance exhaust system jets on carb. Should be good to go for the mud.
