On 350x trikes Honda had extra wires in the head light housing area to plug the speedo ( or trip meter) into so if lights was on the speedo (or trip meter ) would light up.
If you don't have those on your trike you could still fab the speedo light into your stock wiring by piggy backing them together.
Thanks for the info - much appreciated. I was hoping there was factory connectors in the wire harness. I don't want to splice into the harness - want to leave it intact/original. I guess I will not bother to have the speedo face illuminated.
they are extra spots on the 200es wiring harness to plug in the speedo light one is green don't remember the other colour
1985 suzuki alt 185
1985 honda atc 250sx
1985 honda atc 200m (all apart)
1984 honda atc 200es
1984 honda atc 200x- need motor, plastics, axle, exhaust.
1984 honda atc 125m- times 2
1985 honda atc 200m all apart
1983 honda atc 200e times 2
1983 honda atc 250r-times 2
1983 honda atc 200 4 parts
1983 honda atc 110 times 3
1979 honda atc 110 smokey
1978 honda atc 90- restored
Have lots of extra parts, if interested email at e_mcy@hotmail.com
What I see on the speedo harness is one each male and one each female on both colors. I'm thinking the speedo harness needs to be connected at the brown wire coming off the main harness. Pull the bullet connector apart and stick the brown wires in to the appropriate connector on the main harness. The same thing for the green. Rather than plugging the speedo in to empty connectors, it looks like Honda intended on using the existing connectors and simply wire it in series. Anytime the light switch is on, there is power present on the brown wire regardless what position the hi/lo switch is in.
