Results 1 to 8 of 8
Thread: 250R leakdown test ?
    Miami,Fla.(305)
    808
    I realized (afterwards) that i had the piston at TDC not BDC when i did my leakdown on my 85 R (shortrod with fresh topend & left crank seal. -Is my test no good. I wont be able to retest till next weekend so i cant just redo it right now & find out. -so i thought id ask....
    It did hold 6psi fine- but dont know if the ports were blocked thus -test no good???? havent started it up yet-outta time.....
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    nicker71's Avatar
    nicker71 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Wright City, Missouri
    385
    Piston position doesn't matter with a leak down test as far as I know. I can see where it would be better to have it down though.
    Slidell, LA
    4,738
    Are you talking about a crankcase pressure test? If so it should hold 6 lbs for 10 minutes regardless of where piston is setting tdc vs bdc.
    Miami,Fla.(305)
    808
    I thought that the piston position was important during leakdown tests?-maybe not???
    But I thought Ive read it before somewhere on 2 stroke leakdown procedure that tbey specify one or the other position? ???
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Miami,Fla.(305)
    808
    Yes-it held 6psi for at least 15 min.
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Miami,Fla.(305)
    808
    I had the sparkplug installed/test was done thru intake manifold...( while piston was at TDC)
    So Im good???
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Slidell, LA
    4,738
    Yes, you are fine.
    Miami,Fla.(305)
    808
    Thank you....
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
