I pulled the clutch off my 200x. I got everything back in, and got the clutch "lever" thats in the case that the clutch cable hooks to, hooked on to the clutch. Yet theres still some decent space inbetween the cover and the case. Do I just have to give it some love taps to get it seated or start bolting it down and let it pull itself to the case? The clutch lifter is seated right. The only thing I could think would be wrong is the clutch lifter place isnt in far enough, but all the bolts are torqued down and wont go in anymore. And should I be able to just pull the clutch lifter out when the case is off or is it suppose to be seated behind the clutch plate lifter?
