Results 1 to 15 of 16
Thread: honda 185s front end swap
    daddy420big is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2014
    benton
    302
    i was woundering if anybody out there has put a 1st gen 200x front on a 82 honda 185s
    dman10's Avatar
    dman10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2013
    Elgin, TX
    402
    I believe you have to cut off the 185s neck and weld the 200X neck on. A lot of work, I don't think it's worth it either. Just go buy a 200X. But that's my personal opinion.
    Quote Originally Posted by tri again View Post
    Cool stuff seems to happen when I'm sleeping.
    Nice to know things happen without me.
    Nov 2012
    Waldoboro, maine
    791
    A member here by the name of Ol Deuce sells an adapter pin. Works real slick.
    82 250r
    83 Big Red
    85 Auto-x
    If you've done business with me please leave me feedback
    http://www.3wheelerworld.com/showthr...ght=Bren_downe
    Scootertrash's Avatar
    In the sticks
    4,638
    Adapter pin?
    Nov 2012
    Waldoboro, maine
    791
    Here ya go…
    http://www.3wheelerworld.com/showthr...tree-on-my-110
    Scooter I'm surprised you haven't heard of this?
    This is going on my 83 BR.
    200x stem on left and 200e stem w/adapter pin plug welded in on right.
ID:	217049 Click image for larger version.
    82 250r
    83 Big Red
    85 Auto-x
    Aug 2007
    Montana
    857
    They really do work !Click image for larger version.
    DO the Best With What you got !
    My Feed back :cool
    San Marcos Ca.
    711
    Hey Ol Deuce, Nice looking 110. Which aftermarket frame is that ? The HPATC or Valley Wheel & Brake ? Thank you for sharing the photo.
    * 1970 US90 Red
    * 1985 ATC 200s
    In the sticks
    4,638
    Quote Originally Posted by Bren_downe View Post
    Here ya go…
    I can't believe I missed this either!
    Is there a thread or pics on how it was made? It would be awesome to put a different suspension on the front of my 200S
    Aug 2014
    South Louisiana
    1,915
    I think you can use any of the sport model atc triples on a 200s. Its just the round light 185s and 110 models that have a different neck. All of the '84 and newer model utility trikes have a similar neck as do the 200x 350x 250r and 250sx. I may be a little off on my assumptions but a 200s front fit on my 85 125m. I have been able to swap quite a few different front between many of my atcs. The stems are different lengths but you can use 1" washer as a spacer.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Aug 2007
    Montana
    857
    If your utilty atc is 1984 and older ! they have the small diameter stem ! the 200x,250r 1st gen / 250Sx, 2nd gen r, are the same group stem! the '86-'87 200x,'85-'87 250r, 350x are in the same group of stem! the Diameter of these stems are the same!!
    the seating base of the stems are different !!!!! Ol Deuce
    My Feed back :cool
    Mar 2014
    benton
    302
    thanks guys .
    Dec 2013
    Mellen,WI
    50
    I cut the stem off my 185 then welded some round stock on the bottom then turned it down to fit into some early gen r tripplesClick image for larger version.
ID:	219783 not completely done yet but...
    All my X's live in the garage
    85-350x
    85-250sx
    82-200 bigred
    81-185s
    84-110
    70's-70
    Aug 2007
    Montana
    857
    Quote Originally Posted by waynekreitzmann View Post
    Post some pictures on what you did!!! Thanks
    My Feed back :cool
    Dec 2013
    Mellen,WI
    50
    I cut the stem off keeping the stops attached then welded a 1.5 in chunk of round stock on the bottom of the stem then chucked it up in a lathe and turned it down to fit the lower triple on an early rClick image for larger version.
    85-350x
    85-250sx
    82-200 bigred
    81-185s
    84-110
    70's-70
    Aug 2007
    Montana
    857
    Thats cool...It's worth the effort to gain a mod to the good on these trikes ! Have you done a test ride yet ????
    My Feed back :cool
