Results 1 to 11 of 11
Thread: What forks are these?
    Feb 2013
    Ontario
    812
    having a hard time telling what these forks are. Same diameter as the 350x fork tube. Has the tab for a front brake drum but has air.
ID:	217139Click image for larger version.
ID:	217140Click image for larger version.
    Blossvale NY
    4,563
    I may be mistaken, but unless I am having a brain fart, it seems the only model Honda that had that type of forks with drum front brake was the SX...
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Aug 2014
    South Louisiana
    1,915
    It's either sx or '81 250r. But those should both be 33mm. 350x has 35mm.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Feb 2013
    Ontario
    812
    Nope neither. Sx had socket heads on the top of the forks. These have the smaller socket with Schrader valve on top. But no mounting holes for a brake if it was for a first gen 250r
    Aug 2014
    South Louisiana
    1,915
    '81 250r came with drum brakes from the factory
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Aug 2014
    South Louisiana
    1,915
    Also could be 200x tubes w/ sx sliders.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Surprise, AZ
    2,428
    If they are 35mm, which you said they are the same as a 350X which is 35mm they they are not ATC forks.
    They are 1982-83 Showa short travel motorcycle forks off a Honda XR200 (They were very short and had a drum front brake)
    Pretty sure on this, but its been a few years since I have held a pair in my hands.Click image for larger version.
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by onformula1 View Post
    I would go with onformula1' s opinion on this one.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    devore,ca
    1,054
    '81 R's were disk on the front.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Feb 2013
    Ontario
    812
    Excellent thanks for the quick responses. I thought I had myself a pair of 350x forks untill I got home with them.
    Toaster556's Avatar
    Toaster556 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2010
    Fraiser Valley, BC, Canada
    176
    Whats the number on Showa label? I have a pair of XL250S forks in my scrap pile that look very similar, but had no bushings on the fork tube. The XR200s do, so they'd make decent parts forks for 83-84 250R or 350Xs.
