Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: 1984 honda 200x rebuild- brands stamped on all aftermarket parts?
    Jun 2014
    Wittmann Arizona USA
    92
    Well i just had a train of thoughts serge through my brain after a tablet to the face. The trike i got from my friends dad i have finally completed the bike after 8 months of hunting down the right parts. A 1984 200x. Man was it trashed! After 2 months i realized the engine was rebuilt because they used that liquid gasket sealant stuff. I started thinking if i took apart the engine and take a look at the parts that were used to rebuild the engine, is there a brand stamped on all the parts? After the tablet greeted my face i started thinking i want to build a performance trike. Hoping i can post a pic in a few mins of the finished bike. As of now the bike is running perfect but i am willing to throw a few hundred into this one. Just need ideas as to what to do to the engine but it will be a snail process build as funds leak in since bills and bills. Lol. I am thinking i will spend about $800 or even a grand in the end if those nerfs do get fabbed. lets have some ideas pls.
    Jun 2014
    92
    <iframe width="480" height="360" src="http://s1378.photobucket.com/user/Kevin_Joshua_Quiroz/embed/slideshow/Mobile%20Uploads"></iframe> the bike i got
    Attached Thumbnails Attached Thumbnails 1435007319938-256135938.jpg   1435007319938-256135938.jpg
    Jan 2013
    minnesota
    5,911
    That looks nice! since it has a high perf pipe, it obviously may have other high perf parts too so yeah, if you want more power than it currently has you will definitely need to find out what the carb, cam, and piston are at the very least . . below is just some general info for a moderate build . . other things like 28 to 30 mm carb and 12.0 compression piston and big cam would be for a more race oriented build but then you need race gas which is pricey.
    The gears will most likely be Honda . . they often have a mark or letter of some sort on them . . the major parts that are often changed from Honda brand during rebuilds are clutches, pistons, rings, sometimes connecting rods and bearings, valves, valve springs and cams.
    The piston and connecting rod should be able to be identified if you post the numbers that are on them . . the origin of the other parts can be a bit more difficult, however, I don’t really know how this info will help much other than maybe determining what compression piston you have because if the cylinder bore is good and you have a high compression piston, then it has already been upgraded t some type of performance one . . the other thing to determine is whether the cam is stock or not . . there are two primary cam mfg’s for those and of you find some numbers on it that people here cant identify then you can email those companies and ask them . . their names are web cams and megacycle cams . . another is, or was powroll.
    As far as perf upgrades, the most common are DG exhaust pipe vut the one they currently sell does not have a spark arrestor but they may have a spark arrestor that will adapt to it . . you need one for many of the ohv parks . . contact the parks and DG for info . . The first one below comes with the head pipe, they just don’t show it.
    http://www.dgperformance.com/dg-perf...odType=Exhaust
    CARBURETOR
    Others might have a better idea here but basically, the stock carb bore is 24 mm and one that is 2 – 3 mm bigger than stock will help, especially if you put a pipe and higher revving cam in it etc . . One option is to use a carb with an accelerator pump but no one here has quite figured out which one to use and what cables to use etc . . There are also lots of Chinese Keihins on ebay for around $35.00 but the air box boot may not fit . . Others here should know . . You can also run a 1983 or earlier XR200 carb which I think is a direct fit and it is 26 mm . . The 2002 and newer models may still be available new . . Irregardless, you may need to hog the inside of your stock boot out if you use it unless you use a round bore carb and the exit hole in the carb is the same size or smaller than the hole in the boot or unless you use an oval bore carb and the exit hole in the carb is no more than 2 mm bigger than the hole in the boot.
    http://www.dgperformance.com/motorcy...st.php?pyID=40
    if you use a Honda xr carb, you can use a 1980 thru 1984 XR200 intake boot . . you can also use an XR200R intake boot but this puts the carb at a different angle so you need to make an airt boot from the air box to the carb.
    This looks like the correct XR200 intake to me.
    http://www.ebay.com/itm/Honda-XR200-...-/361307993734
    CAM
    This depends on your compression and your goal . . in general, the bigger the cam is, the less bottom end you will have but the more top end you will have . . they basically just move the entire rpm range up . . to compensate for the loss of bottom end you can simply install numerically higher final drive gear ratio . . this is done by using a smaller front or bigger rear sprocket . . a 4 tooth change on the rear sprocket equals around a 1 tooth change on the front sprocket . . the stock xr200 motorcycle cam is a common mild to moderate upgrade . . check with the cam mfgs below for others . . keep in mind it is incredibly easy to get a cam that is too big for your app.
    http://www.webcamshafts.com/index_bl...le_search.html
    http://www.megacyclecams.com/
    HIGH COMPRESSION PISTON
    These will give you a little more power everywhere and are a must if you run a bigger cam, but you will definitely need to run premium gas at the very least . . some places make a 10.0 compression piston also . . the place below makes a 10.25.
    http://www.wiseco.com/ProductSearch.aspx
    IGNITION TIMING
    This is the most commonly overlooked area and its one where you can gain power and throttle response . . The book says your timing is 5 degrees btdc at idle of around 1400 rpm and 30 degrees btdc at 3150 rpm . . I would advance it 5 degrees, reset the idle speed and see if it runs better . . if it does and does not ping under acceleration, it is good.
    One good combo for a noticeable increase in power for premium gas is:
    Wiseco 10.25 piston
    27 mm DG carb
    DG exhaust pipe
    WEB CAM p/n 340b or 389a . . the 340b will have more bottom end power but if you like rpm’s then get the 389a and try I tooth smaller on your front sprocket.
    IGNITION TIMING – advance it 5 degrees
    The above set up with the 340b cam and smaller sprocket will very strong.
    Jun 2014
    92
    That carb i through on there myself to get the bike running its a ebay mikuni i cant remember bore size though i believe 24. And i have found afew of these parts a bit cheaper.is the supertrapp not a good enough pipe to run? I believe its a 1/4 incher bigger diameter than the stock pipe i would have thought it was perfect but whatever works best. I wanted to keep that pipe though since this bike is supposed to be chrome and blue lol. Is it restrictive to any power gains?
    What is the dg carb kit ive always wondered since theres no image.
    This bike wont be used for racing that i know of right now since im so far from the parks. Its gonna be more of a thrilling trail rider that comes arou d the bend sideways lol.
    And i plan to do this all mostly on my own so maching the head is out of the question since i dont have access to a shop.
    So far all parts i have found that i think would work is a wiseco 10.25 comp vesrah crank shaft d.i.d. cam chain and maybe use oem cam gears and then kibble white spring set seals and guides there are kibblewhite valves i seen too which cost a pretty penny ×5 . i also seen some k&l valves are those any good to jse in place of the kibblewhite?
    I mean i know i could do my build with bronco atv parts and shindy parts but i feel these would give way or break or just melt away.
    And for the cam.... That spreadsheet confuses me lol. Is the new cam 161 or do you send in yours for the rebuild for web cam inc.
    Oh me and ignition timing are like the best kf friends now lol.
    I beleive with a top rebuild a clutch kit would be needed?
    Thanks by the way barnett oh and by the way check out the blueing on the pipe lol i did that on accident.
    Jan 2013
    minnesota
    5,911
    no prob, you're welcome.
    why do you want a vesrah crank assembly?
    if your pretty happy with the way it runs then keep that pipe but it looks like crap because half is chrome and half is burnt . . for the cost of re-chroming it, you could have a better overall pipe from dg . . it will have a broader power band . . sell yours on ebay for $75.00 . . you can also buy high temp chrome paint and spray that on the toasted part . . it wont look horrible . . chrome can get rusty fast so you can also buy the cheap fg pipe and send it out to get high temp aluminized like chrome.
    shindy parts are number 1 oem quality . . they are made in japan and their pistons are made by an oem piston mfg ART.
    call dg for info on the carb . . i do noit know what it includes but it may just be the carb
    you only need to machine the head if your valves leak or you use a huge cam.
    the web cams are modified stock cams . . send yours in with $161.00 and they will send you one that is already finished or pay the $30.00 core charge and keep yours.
    you only need a new clutch if yours starts slipping . . it may have a high perf clutch in it now . . it may also have high perf springs but we would need the spring length and clutch disc thicknesses to try and determine if it is stock or not . . high perf springs are a pita if you pull the clutch in often . . you can also preload your springs around .040" if they are stock
    Mar 2007
    Texas
    5,045
    first off, $800 will get you some "basic" stuff. you can get a wiseco piston, complete gasket and oil seal kits from Athena or Cometic, get clutch plates, get a valve job with new valves and bore/honing for new piston. You may squeeze in a new sprocket and chain set. If your really lucky, you can get a 26-28mm Mikuni carb off ebay as well.
    good luck.
    ________________
    https://www.mikesatvfix.com
    Jun 2014
    92
    I was just thinking the crank would need to be replaced along with the piston. Is vesrah not that good?
    I know lol. It is burnt i thought i could polish it out but maybe not.
    Alright so shindy is good ok.
    Im only going for a mid performance cam so that wont be needed if the valves dont leak.
    Ill give dg a call when possible. And thanks for helping me understand that. Lol it sounds cheaper now that someone explains it to me.
    Oh and the clutch feels real tight now that i think of it lol. My other bike has a softer clutch so i might still buy the kit.
    Jun 2014
    92
    Quote Originally Posted by oscarmayer View Post
    good luck.
    Sorry i meant to say that ill spend 800 or a grand on parts only. If i do want to pay for machining ill pay what it take so up to a 1500 or so to the build ill spend.
    Jun 2014
    92
    good luck.
    So far for 700 or so and a shipping cost can get me a pipe, cam, valve kit, engine gasket kit, piston kit and a cam chain. But i could spend differently if i do decide to have my head and jug machined. I could spend about 100 more for the right parts. I
    I already have a mikuni i just checkedit.it is a 25.14 would that work with a rejet or should i still go bigger?
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by KevinJ97 View Post
    ok, i really dont know what to suggest . . most people only replace broken or obviously bad parts . . it sounds to me like you want to replace parts that have no obvious sign of being bad like the crank and the clutch so all i can think of to say that is vesrah does not list a crank assy . . they only list a connecting rod kit.
    it is owned by a japanese person, and the way they advertise, they try to make it sound like their parts are japanese made which i know not all of them are . . this does not mean they aren't good though but i prefer japanese made parts if i have a choice . . my guess is that their rod kit is as decent as most others but there are others to choose from if you only need a rod kit . . the main bearings can be bought separately . . i would only use japanese bearings.
    for mid performance, i would use the 340b cam unless somebody has a better idea.
    for the pipe, you can try the one you have first . . if you want more bottom end then get the dg.
    as far as the higher compression piston goes, you must have your bore professionally measured for taper and out of round . . if it is out by around .015 inches in either direction, you should have it bored out to the next bigger size.
    i have no idea what you mean by tight clutch . . is it hard to pull in? . . if so then it probably has high perf plates and springs in it already.
    also, find out if your cam and piston are stock or not before you buy other ones.
    Jun 2014
    92
    I meant connecting rod lol. The heat is making me think differently.
    I compaired the cams from megacycle to webcam man there is a differnce there lol. For megacycle i would have to call and request for prices right?
    Thats a good idea to have it checked and possibly bored out. Ill make it my top priority.
    My first dissasembly will be in these two days or a week to check whats going on with my kicker gears.
    As i have said i have 2 200x both are 1984. I have nicknamed the one in this blog as brittany. The other i named V. I.. The kickers are very different in aspect of how far the move and with how much needed force. V. I. Has no trouble starting 1 or 2 kicks and the kicker goes far below the crank cases and never slips. I thought it had a kicker gear upgrade which honda had kits for but it doesnt have the stamp so no clue there. Brittany on the other hand takes multiple tries to start the bike as the kicks tends to slip or not be in place for a start. Luckily i havent took her for a real ride to get stranded. Her kicker stops at foot peg height. Any ideas there. This still relates to my thread if someone says it doesnt, as i would like to know if the kicker in V. I. Is aftermarket part if it is stamped or not.
    Thanks again barnett and oscarmayer.
    Mar 2007
    Texas
    5,045
    that depends on the piston, compression, cam, and mods you have such as carb and are you running stock airbox or bolt on filter to carb setup? best thing is to leave it where it is at and build it and see what happens. use the plug to tune from there. start off by first tuning the start up (after you broke it in gently and not ridden it hardly just a basic ruin through to seat the rings).
    once you get to that point and have tuned it for idle then from there you can go to mid with needle and mixture screw, and finally top end rest of the throttle with main jet sizing.
    ________________
    Jun 2014
    92
    Well I run an air box so I won't suck up any water or dirt.
    I was planning on taking it real slow to build so not much will be changed out at once so I'll do the piston and cam then go to carb then exhaust.
    And right I have read that to not go any further than half throttle or so to not warp the rings or something when still in the break in period.
    And thanks again. this will help me out
    Jan 2013
    minnesota
    5,911
    one thing i can suggest is to use regular oil [not synthetic] for break in . . i sometimes use joe gibbs break in oil . . royal purple also has one but i prefer the gibbs.
    after break in, i would switch to a high quality group IV or V full synthetic.
    Jun 2014
    92
    Haha thanks I've been meaning to ask about oil.
    Thanks for the tip.
