Results 1 to 10 of 10
Thread: 1985 Honda 200X Airbox Lid Rubber Seal/Gasket
    Jun 2015
    Jefferson County, WV
    70
    Does anyone have a source for one of these? Part number 12 in the attached pic. Thanks!
Name:	Screen Shot 2015-06-29 at 6.30.24 PM.jpg
    Wanted:
    1985 200X OEM Airbox Thin Vacuum Line
    1985 200X OEM Swing Arm Skid Plate
    Dec 2011
    Grand Rapids, MI.
    679
    I hate to say it but unless you find someone who has one laying around you are out of luck. I wouldn't say it is that vital though if you are worried about it.
    1986 KLT 185
    1984 200S
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by thehorse13 View Post
    sure . . here's an nos one . . last one left.
    http://www.cmsnl.com/honda-atc200x-1.../#.VZI85lLLDdU
    Jun 2015
    70
    55 dollars shipped sounds like a bit much to me though. Ahhh well. Thanks for the heads up barnett468.
    ebaccm26, I was hoping that I could find a cheap seal just for the sake of completeness.
    Thanks again fellas.
    Wanted:
    May 2015
    San Diego, CA
    1,797
    I forgot to take a photo of the cage but will. It's on the 200X so if everything looks the same it should work.
    I wonder if you can find a lid on ebay or something. I know air boxes in general act as resonators so if it leaks air to much it could affect performance.
    Jun 2015
    70
    Yep. Exactly.
    I did buy an airbox lid and put it on the trike already. It fits nice and snug but because I hate having things incomplete, I went out searching for the seal. Given the nice fit I currently have, I believe that the airbox will serve the purpose that factory engineers intended. The nice thing is that I bought the entire airbox and it came with all of the stock mounting metal for the stock air cleaner. I will be ordering one of those this week.
    In the end, the only thing that was missing is this damn seal. lol.
    Wanted:
    Las Vegas, NV.
    2,493
    If you found out what the seal is made out of (thin rubber, foam) I'm sure one could be made fairly easily for just a few dollars.
    Jan 2013
    minnesota
    5,911
    you can simply go to home depot and tell them you want to look at the adhesive backed seals . . they use then in many apps and have a few different types that are maybe 3/16" thick . . some of them are used on the edge of sliding screens . . if you find one the right thickness but it is too wide, just cut it with a pair of scissors.
    Jan 2013
    minnesota
    5,911
    Jun 2015
    70
    Thanks fellas. I will take a trip over to home depot after taking a few measurements.
    Wanted:
