Results 1 to 2 of 2
Thread: Swapping thumb throttle for a twist throttle
    May 2015
    Cumming, GA
    15
    I recently picked up a Kawasaki klt 160 off craigslist for a killer deal. I also recentlywas riding it and did the inevitable and flipped it. Smashed up the housing for the thumb throttle. When I first got the trike, I was toying with the idea of putting a twist throttle on. What would I need to do to go about doing this swap. Anyone with experience of doing this. I've seen it done on 2 different kit 160s, and tried to get some information, but they either didn't reply or couldn't remember. Basically I want to know if a generic eBay twist throttle will be able to swap over, or should I look for a similar Kawasaki model and use the twist throttle off that? Thanks in advance
    Surprise, AZ
    2,428
    I would call Motion Pro and tell them you want one of their throttles and cable for your trike/carb.
    That will be the easiest and will remove the guess work/experimenting.
    Sent from my SM-G386T1 using Tapatalk
