Page 20 of 39 FirstFirst ... 10 18 19 20 21 22 30 ... LastLast
Results 286 to 300 of 580
Thread: Random 1980s racing pictures
  1. #286
    Nov 2014
    Chico,CA
    473
    if you are not having to counter steer you are going to slow
  2. #287
    Nov 2014
    Chico,CA
    473
    little on track action for your Friday
ID:	220765 Click image for larger version.
ID:	220766 Click image for larger version.
ID:	220768 Click image for larger version.
ID:	220769 Click image for larger version.
ID:	220775 Click image for larger version.
ID:	220778 Click image for larger version.
    couple Rotax shots from today
    the dark spots around the footpegs is the most stubborn dirt i can remember, been scrubbing and scrubbing but so far it is not impressed by my efforts
ID:	220812 Click image for larger version.
    saw this dent in the frame for the first time today when i turned it over, about brought a tear to my eye..and i have not a clue what the heck i hit to of done it..bad 1984 John, bad
    any advice on how to get this bearing off the bottom clamp? i wanna replace it but with the aluminum stem i do not think heating the bearing would have its normal result
  3. #288
    Surprise, AZ
    2,428
    The frame looks like you cased it, I have done that a few times on MX bikes with out a skid plate or glide plate, they can be removed.
    On the stem just jig it up and press the stem down until the bearing comes off, soak it with KROIL or other for a few hour before. It will take a bit off pressure then it will "pop" then it will come right off.
    Heating it will make it worst.
    Sent from my SM-G386T1 using Tapatalk
  4. #289
    Nov 2014
    Chico,CA
    473
    Couple XR500 and a out of focus KTM495
ID:	220841 Click image for larger version.
ID:	220842 Click image for larger version.
    Ordered all the gaskets and o-rings yesterday for the Rotax, only came to $76 with tax and shipping...was expecting it to be twice that for all NOS stuff. Thank you again for sending me to Tony Murphy as that has worked out awesome. He even found me a stash of new Wisco reproductions of my piston and ring that Al Roberts in Texas has in stock.
    Decided to fix the sleeve with JBweld, should work fine since its not on the compression side and just needs to be there to keep the o-ring in place.
    Starting to sort out the controls, going with a Grimeca front master cylinder but still shopping around for the best price.
    Think i am gonna use these plain black steel bars as my Sundahl bars need to be bead blasted because of rust pitting and anything i do to them just removes the gold surfacing.
  5. #290
    Surprise, AZ
    2,428
    Congrats on the piston, the Grimecas are cool nostalgic master cylinders, I wish they stopped and were not as mushy as the modern stuff, that looks like a Magura clutch lever are those Domino grips?
  6. #291
    Nov 2014
    Chico,CA
    473
    Yeah new Magura clutch perch because the one that was on the Rotax was a Magura front brake so it was facing upside down and that bugged me and it had a lot of play from use so it got shelved. I like this style of grip because they clear the clutch lever when it is pulled in better then full donut type grips do.
    This is the brake i would get if i could afford it but with shipping it is $500.00 so yeah that is not happening.
    My current task while i wait for engine stuffs. Trying to track down who has parts for the older 1980s style Ohlins shocks and does service on them but no luck so far. Really wanna get this shock taken apart so i can find out if it has a travel limiter inside or does it use a short shock shaft, if it has a limiter i can have it removed the return the bike to its normal full travel setup that i prefer the look of. At the least i want the spring given a fresh yellow powder coat.
  7. #292
    Surprise, AZ
    2,428
    Those grips were comfortable and no blisters, that Brembo is cool looking, I remember them but they were before my time by a couple of years, so I never rode with one
  8. #293
    Jan 2013
    minnesota
    5,911
    ohlins shock reuilders in sonoma phone 707-938-5664
    http://performanceshock.com/index.ph...roducts_id=228
    or try
    http://www.racetech.com/
  9. #294
    Surprise, AZ
    2,428
    John, I sent you a PM
  10. #295
    Nov 2014
    Chico,CA
    473
    The world was a better place when men lined up every weekend to race their Tri-Motos.
ID:	220860 Click image for larger version.
ID:	220861 Click image for larger version.
    @barrnet468 - Thank you, I sent Racetech and OhlinsUSA email's yesterday. But i am gonna have onformula1 work on it as he has offered to help and as it just needs to be torn down and inspected for stuff gone awry from age and checked to see if he can return it to the full motocross suspension height by removing a down travel limiter i suspect is under the piston so it should not be a major chore.
  11. #296
    phantomtracer's Avatar
    phantomtracer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    392
    Great pics again, where are those last three shots from?
    Looks like every person racing has custom mods. So cool
  12. #297
    Nov 2014
    Chico,CA
    473
    @phantomtracer - First pic is from Carnegie OHV park in late 81, center pic is a local race at Indian Dunes early 82 and the third pic is my local track, CycleLand Speedway, mid 82.
    #17 on the Tri Moto is my friend Bobby, he was a exc at Maier who got sick of company life so he moved to Chico and opened up a ATV hopup shop called "Backwoods Racing" or some such, the yellow jersey you see me wearing in a lot of these shots on my 200 Nicholson is his shop's logo. He was a super, super nice guy and from what i heard was a national caliber woods rider on a dirt bike and raced the Blackwater a few times but i never got to ride dirt bikes with him.
    Some Rotax before it was a pile of parts on my bench
    *for onformula1*
    I want to mount the reservoir where it is in these photos but with the hose coming directly to it from the shock instead of wrapping around like it does now.
ID:	220864 Click image for larger version.
ID:	220865 Click image for larger version.
  13. #298
    Surprise, AZ
    2,428
    ^ That would look a lot cleaner, plus those reservoirs hold only 10% of the total length in fluid which is not a lot, so cooling is not a huge issue.
    I may work better to have the banjo bolt clocked the opposite way toward the reservoir too.
  14. #299
    Surprise, AZ
    2,428
    John across the bottom of the spring I see purple paint lines and blue paint lines, but that is all I can see there should be another set of paint lines more than likely two more blue or two more purple. (They maybe chipped off)
    Are they still there?
  15. #300
    Nov 2014
    Chico,CA
    473
    It is has four purple and two blue, can just barely see the paint left of two of the lines.
