Results 1 to 15 of 18
Thread: 350x floating ground
    Sep 2014
    minnesota
    24
    Installled a goki starter and battery now I want to add full wave regulator rectifier. do I need to unhook the other side of the white wire on the lighting coil and hook it to the new regulator along with the white coming out of the stator?
    Apr 2012
    USA
    4,129
    Based on this google image I found, you need to put two hots from the stator (AC power) to the regulator, other pics suggested both will be yellow on the regulator side. One wire will need to be a ground, and the last pin will be the 12v for the battery / accessories.
    http://i397.photobucket.com/albums/p...regulator2.jpg
    I haven't wired one of these up in a non-battery machine, so I'm just going off my understanding of diagrams and the image google brought up.
    Sep 2014
    minnesota
    24
    looking at this pic I need to remove the lighting coil ground and run it out to the ne reg/,rec to get dc volts
    Sep 2014
    minnesota
    24
    or do you think I can cut the green ground and run the end coming out of the cover to the new reg/rec.
    Sep 2014
    minnesota
    24
    frustrating just want the battery to charge after installing a goki starter. installed it last week and fried the ac regulator and goki diode that they use inline
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    The above picture is correct with the two yellow wires connected to the white (light power) and green (ground). In that picture the green wire has been floated inside the stator. If you float the green wire, you can use the frame as ground for your dc power. If you simply use the green wire as the other input for the rectifier/regulator without floating it first, it will not work properly.
    If you choose not to float the ground, you can convert to dc power, however you cannot not use the frame as ground but must ground the electronics back to the battery or capacitor you are using.
    Here is how I wired my 350x to convert the lights to dc power for led without floating the ground because I was lazy.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    Sep 2014
    minnesota
    24
    so you left the green wire coming out of the alternator attached inside the cover but cut it so its not grounded to the frame and then hooked up to one of the yellow wires.
    do I need anything internally where the lighting coil goes to ground or just use the green wire once its not gounded to the frame
    Sep 2014
    minnesota
    24
    see how in my image the other side of the lighting coil was removed from ground and they attached it to the green wire
    dosent look like you disconnected it internally in the cover but tied in outside of the cover
    just don't want to ruin anymore stuff
    devore,ca
    1,054
    Are you just trying to get the charging system to work or are you doing something else ?. The goki's come with an inline diode to the battery that converts the a/c to d/c. Maybe I'm missing something with your intended set up.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    f76's Avatar
    Jun 2014
    South Dakota
    323
    I didn't touch anything internally. I simply cut the green ground and used that as the "other yellow" wire to feed the rec/reg. You can use the green wire come straight out from the stator without doing anything internally. Be aware that the green wire ground connects to multiple other green ground wires in various places inside the wiring harness.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    Sep 2014
    minnesota
    24
    ok I will try it
    Sep 2014
    minnesota
    24
    got it all hooked up lights on battery but the starter motor is grounded when bolted to the case which is connected to the frame. so I have to ground the battery negative side to the frame or the starter wont work. I am going to take the case off and see if I can get to the other side of the lighting coil and float the ground off it. Right now it is charging but no more than how goki has them wired using a inline diode. which act like a trickle charge.
    May 2015
    Clayton, NC
    5
    I have been working on the GOKI install myself and don't have their "yellow" wire with the diode made into it. I am heading down the route of installing an aftermarket rectifier/regulator.
    Anyway, was trying to wrap my head around the ground situation. You would basically take the ground wire with the "D" ring on it that attaches to the frame under the left side of the tank and run it back to the battery. Then you have to ground the starter to the battery with another wire. So basically after you float the ground off the stator, you turn right back around and ground the battery to the starter, which is bolted to the frame. What is the point?
    Sep 2014
    minnesota
    24
    you must take the ground wire off the stator inside the cover and attach it to a full wave reg,rec. not the oem reg. the yellow wire from goki contained a simple diode (one way valve) so the battery don't drain. My goki diode (yellow wire ) burned up and my oem regulator. I ordered a simple 2wire reg/rec to hook it up like stock and a full wave reg/rec to run the lights on battery DC and get a full wave charge for battery. I have not finished this project yet but will return to it shortly and update the post on which way I hooked it up.
    May 2015
    Clayton, NC
    5
    Right, forgot to mention that I was going to float the ground.
    So after that's done, I've read that the factory green ground wire shouldn't ground to the frame. It should be rerouted back to the negative on the battery.
    My question now is how to properly ground the battery and starter. The starter is technically grounded to the frame via the motor. So should I simply ground the battery to the frame? This is where I don't understand why the green ground that used to bolt to the frame should be disconnected from the frame. Maybe it doesn't really matter, I just don't know that much about it.
