Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: 350x floating ground
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    If you float the ground from the stator, your dc powered electronics (starter, lights, etc.) can be frame grounded.
    After you run your two inputs (your light circuit power from the stator and the floated ground) into the rectifier/regulator, you run the rec/reg output ground or negative to the battery and then to the frame.
    You can leave the green ground wire connected to the frame, as long as you have floated the ground.
    If you have not floated the light circuit ground, you cannot use the frame as ground for any electronics using the dc power. These electronics must ground back to the battery or capacitor.
    The goki setup requires the frame to be used as ground as the starter is grounded to the frame. I don't have the goki installation instructions so I can't comment on how they go about handling the conversion and grounding and such.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    May 2015
    Clayton, NC
    5
    Thanks for the reply! I bought the Trail Tech rect/reg yesterday and asked them about it while I had them on the phone and your info is spot on with what they said.
    Goki just used a diode in their yellow wire setup but apparently that's not the best way to go about it. I also swapped in a 400ex switch for a clean starter button too so should be very stock looking when I get done.
    Great info on the board that made this possible.
    f76's Avatar
    Jun 2014
    South Dakota
    323
    It took me awhile to get my head wrapped around it, but once I understood the floating ground and such, it made sense. The 400ex switch works great and looks oem. I used one on my 200x with goki starter.
    Glad to hear it's all working out for you!
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
